Question about Miele Refrigerators
Alarm light flashing
Miele refrigerator ktn 2450 s
I have a Miele Kfn 8452 sd who blink 2 leds both in the same time, freezer and super freeze,and i hear the sound alarm, i need to know whats the problem, what is damaged?
Press alarm button once
either left door open too long or temperature too low
adjust fridge to 4 centigrade
freezer to -17 centigrade
Dec 28, 2015 | Miele Refrigerators
Inhave just reurned from a short holiday and found My Miele f1313s freezer has the alarm light flashing. Thoughts?
Make sure you have enough amps in the outlet its plugged into. The kitchen outlet might of had more amps than the garage outlet. Also, try unplugging it for a few seconds then plug it back it which might reset it.
Sep 20, 2014 | Miele 3.7 cu. ft. / 105 liter Upright...
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Why is alarm light flashing?
Hello friend, I appreciate your inquiry!
Based off what you have described the alarm is flashing on your Frigidaire refrigerator. Normally, the alarm will flash when internal temperature has risen too high or the door has been left open. Hopefully this information is helpful to you. -Matt
Apr 07, 2014 | Frigidaire Refrigerators
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
Miele fridge keeps beeping
Door is open (shut it)
or
seal on door is broken ( replace it)
or
temperature dropped too low ( reduce it)
or
door was lett open too long (reset alarm)
- after ffix
press alarm buttons once to switch of beeps
Oct 20, 2013 | Miele KFN8862SD Bottom Freezer...
The alarm on our Miele 8462 was sounding and the display flashing at -4 degrees. The door had not been left open and the ventilation appears unblocked. Any ideas?
you may have a bad thermostat, or the fan on the defrost is caught in defrost cycle intermittantly. My first advice is to simply take all the perishables out of the freezer and refrigerator and unplug it for the wall. leave it unplugged with the doors open for at least 12 yours, plug it back in and wait another 12 hours and then report back to me if has again started to work properly.
Mar 17, 2011 | Miele KFN8762SDED Bottom Freezer...
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
Refrigerators Logo
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
