Question about WhatsApp Messenger
Samsung Galaxy Note II GT-N7100 Free Puk Code
Forgot my pin and puk number
I need my puk number for a galaxy core prime
Hi Tammy, If you've locked your cell phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your cell phone again sometime in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
May 11, 2016 | Samsung Galaxy Cell Phones
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
How can i unlock my Samsung GT-E2530 B.IMEI 35188405182498/7
Do you mean the network unlock?You can approach Wickedunlock.com and get the required unlock code for your Samsung GT E2530.You need to specify the country,locked network and based on the availability get the unlock code along with free unlock instructions.
Sep 06, 2013 | Xell Battery for Samsung GT-N7100,...
Samsung galaxy note 2 locked on at&t
Hi, You can unlock your Samsung Galaxy Note II locked to AT&T network safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy Note 2 from www.wickedunlock.com at affordable cost with easy unlocking guide.
May 18, 2013 | Yoobao Samsung EB595675LU battery for...
Samsung galaxy note 2 unlock from at&t
Hi, You can unlock a Samsung Galaxy Note II locked to AT&T network safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy Note II from www.wickedunlock.com at affordable cost with easy unlocking guide. Good luck mate.
Unlock samsung..
Dear Brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 11, 2012 | Samsung Galaxy Note II N7100 Unlocked...
Help me unlock my samsung note 2 gt n7100
Dear:
Dec 11, 2012 | Samsung Cell Phones
Doesn't show contact of sim card of samsung galaxy GT-s5570 can u give me format code of samsung GT-s5570
I'm Ben and -- hopefully -- I can provide some meaningful
assistance.
It seems that your SIM card is locked.
SIM CARD:
If you enter a wrong PIN code too many times, usually three,
your SIM will lock itself. This protects you from someone using
your personal information or making calls if your cell phone is
lost or stolen. You may see "PIN blocked" or Enter PUK code" on
your cell phone display. The PUK code stands for PIN Unblocking
Key. In the U.S., the PUK code is rarely provided when you get
your subscription.
If you do not have your PUK code, contact the Customer Care
customer again. Give them your phone number and once they
are sure it is really you, they will give you the PUK code.
You will then be asked to set a new PIN code. Once you have
your PUK be sure to keep it in a safe place.
Note that if you enter a wrong PUK 10 times in a row, the SIM
will be permanently blocked, and you'll need to purchase a new
SIM card.
Jun 17, 2012 | Samsung Galaxy GT-S5570
WhatsApp Messenger Logo
165 people viewed this question
Top WhatsApp Apps Experts
Sunil Pratap Singh
Sunil Pratap Singh
Sun Kevin
Sun Kevin
Level 1 Expert
David Payne
David Payne
Are you a WhatsApp App Expert? Answer questions, earn points and help others
