Question about Briggs & Stratton Garden
What is the recommended ft pounds of torque for a B&S 24 HP motor, model no. 446677
What is the recommended ft pounds of torque for the head bolds for the B&S engine that I am working on - model no. 446677 Thanks
3 Suggested Answers
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
  • 252 Answers
SOURCE: NEED TORQUE SETTINGS FOR 18 HP MODEL
hi
con rod bolt torques are 150 in/lb or 12.4 ft/ lb
cyl head bolt torque is 220 in/lb or 18.5 ft/lb
here is website for parts and manual
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=31h777-0297-e1
i would torque them in this sequence
start from bolt centre top , then bolt centre bottom, then bolt left upper , then bolt btm right, then bolt bottom left , then bolt upper right , then bolt centre left
should be 7 bolts 5/16 x unc
check out website its good so is www.partstree.com
cheers paul
Posted on Aug 17, 2010
How much torque should be applied to a chrysler 300 2006 3.5L and torque for the intake manifold?
Data I have found indicates that a torque of 250 inch pounds is appropriate for these 13mm bolts. Torque them in a circular pattern starting from the center pulling through several times. DO NOT OVERTIGHTEN!
Nov 26, 2014 | 2006 Chrysler 300
2000 model mazda 323 astina cylinder head bolt torque specs
Three stages with new bolts (a must), 1st 60 pounds, then 70 pounds then final torque is 80 FT Pounds.
Feb 16, 2012 | Mazda 323 Cars & Trucks
NEED TORQUE SETTINGS FOR 18 HP MODEL 31H777-0297-E1. ROD BOLTS AND HEAD BOLTS. IS THERE A PATTERN TO TIGHTENING HEAD BOLDS
hi
cheers paul
Aug 16, 2010 | Briggs & Stratton Garden
94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Sep 17, 2009 | 1994 Mazda 2WD B Series Pickup
What is the tension on cylinder head bolts for a jeep grand cherokee 307935 4 litre, 6 cylinder, 1999, petrol motor.
Coat threads of left hand front bolt with sealant: 1st - step; - 22 ft./lbs. 2nd - step; - 45 ft./lbs. 3rd - step, all bolts except L.H. front bolt; - 110 ft./lbs. 4th - step, L.H. front bolt; - 100 ft./lbs. fig100.png
Sep 05, 2009 | 1999 Jeep Grand Cherokee
I need to know how much pounds is apliied to a 350 chevy cylinder heads
What is the year and model of your vehicle?
On a 1968 Chevy 350 small block it is 60-70 ft/lbs with sealant applied
When torqueing the heads, it is helpful to start at around 25 ft. lbs. and torque all the bolts, then go to 50 ft. lbs., and finally, your specified torque. Doing this in increments will help give a nice even torque to the heads
Jul 25, 2009 | Chevrolet Classic Cars & Trucks
Need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Jul 10, 2009 | Garden
Cylinder head torque specs
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
1991 jeep cherokee sport 4.0
 For your 1991 Jeep Cherokee 2WD 4.0L MFI :
  Foot pounds (Final torque)
  Note:
  Torque sequence ------------------
  front    | 12  8   4   1   5   9  13 |
  of | |
  engine | 11  7   3   2   6   10 14 |
Final torque must be reached in 3 equal steps
  Step 1: torque all bolts (except bolt 11)
  to 110 Ft/Lbs
  Step 2: torque bolt 11 to 100 Ft/Lbs
Recheck final torque in sequence
Sep 30, 2008 | 1991 Jeep Cherokee Briarwood
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
