Question about Panasonic KX DT343-B Digital phone - Black
NO DIAL TONE ON ALL HANDSETS - Panasonic KX DT343-B Digital phone - Black
5 Suggested Answers
  • 168 Answers
SOURCE: No tones, just a click when dialing
Try setting it on pulse, then hear it click when you push the number, if it works switch it back and try agian
Posted on Mar 05, 2009
  • 12 Answers
SOURCE: all lights on base are blinking, no dial tone
walk close to the base and check that the handset is working if it is try taking the battery out of the handset wait a moment and put it back in if that doesnt reset it you will have to look in your owners manual and see how to reset the hanset autherization so that the base will see it. if you down have a copy of the owners manual you can download a copy off the manufactuers website or manuals.com
Posted on Jul 19, 2009
Phonesmith
  • 113 Answers
SOURCE: Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Posted on Mar 19, 2010
Testimonial: "Thanks Heaps Buddy"
fgrixti
  • 89 Answers
SOURCE: my panasonic cordless phone model # KX-TG2258S the
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
Posted on May 06, 2011
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
Handset displays "Line in Use" no dialing tone and
I can't get dial tone either. Let me know if you find a solution please.
Dec 12, 2010 | Siemens Gigaset 4015 Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Panasonic KX DT343-B Digital phone - Black Logo
26 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
