Question about Belkin F1DL102P 2-port KVM Switch
Micrsosoft optical desktop 1000 to Belkin KVM switch
Loaded a new MS keyboard and mouse but my KVM switch will only see the mouse on both computers and will not see the keyboard on either! The MS radio device only has 1 USB connection instead of the 2 on previous units. My KVM is an old and trusted one with PS2 connections and I use USB to PS2 connectors. Any suggestions please?
He's right its a hwardware problem on the KVM not BROKE just not supported. There was a day when KVM's just worked, that day has passed. I have bought several and returned all because of one thing or another....point....keep the receipts and do not buy from someplace that does not have return policy.
Posted on Aug 30, 2007
    Sergeant:
  • 279 Answers
This is a common problem with a number of KVM switches - this model in particular. I have heard that the Bytecc BT-2000 connector will work in SOME cases: *5.99 on Newegg - http://www.newegg.com/Product/Product.aspx?Item=N82E16812101117 It might be worth the investment to give it a try, if you haven't already tried this. Bytecc does make very high quality hardware. However, if that doesn't work, there's really not much else that can be done, other than replacing the KVM with one designed to run off a single USB port. Hate giving bad news like that. It's a hardware limitation, I'm afraid.
6ya staff
SOURCE:
How do I connect a usb mouse and keyboard to ps2 kvm switch?
usb to ps2 converter, the sell them for like 30$ but you can go to radioshack and buy a keyboard for that with the little adapter
Mar 30, 2013 | Belkin F1DL102P 2-port KVM Switch
MS wireless 1000 keyboard function keys
The "F Lock" is a dual function key,try pressing this key and should fix your problem.
Miklo
Jan 26, 2010 | Microsoft Wireless Optical Desktop 1000...
Can I use a new MS wireless mouse to replace my existing MS wireless mouse. Currently my mouse and keyboard connect together on the same wireless USB device. Could the new mouse be detected and be used...
I suppose there is a reset button on the keyboard or the software provided so I suppose it could be possible, I don't know.
I use a Microsoft Wired Keyboard...
But Best of luck.
Jul 21, 2009 | Microsoft Wireless Optical Desktop Pro +...
2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Belkin 2-port kvm switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
My Keyboard only works on one PC but the monitor and mouse works on both?
Plug the key board and mouse directly into the computer that doesn't work, let it recognize the hardware and then reboot. After reboot, plug the keyboard and mouse back into the KVM and reboot again. That solved the problem for me. Most likely, the computer that doesn't work has never loaded the driver for that key board and does not recognize the input sent from the KVM.
Oct 09, 2007 | Belkin F1DK102U 2-port KVM Switch
Open Questions:
See all Belkin F1DL102P 2-port KVM Switch Questions
Belkin F1DL102P 2-port KVM Switch Logo
128 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
