Question about Altec Lansing VS2621 Speakers
How to open left speaker - Altec Lansing VS2621 Speakers
If you remove the front fabric cover by levering it off using a flat head screw driver, it will reveal the screws to open the speaker up. This is the same for both the left and right speakers.How to open left speaker - 2_6_2016_3_29_16_pm.jpg
Posted on Feb 06, 2016
  • Anonymous Apr 30, 2016
    Thank you. Your information was helpful.
The wiring route for rear speakers. Front to back on 1990 Oldsmobile tornado/trofeao
The wires run under the door opening sill plates, usually on the drivers side but check both sides.
The wire colors should be as below.
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 05, 2016 | Oldsmobile Cars & Trucks
Hello...my left speaker doesnt work
It might be a wiring issue or your computer. What speakers do you use in general? Because I have the same problem now and it seems like the wiring is loose inside, so I can only get it to work by twisting and turning the wire for now.
So yeah
Try doing this:
Open up your left speaker and see if the wiring is disconnected. If it is, connect it using a soldering iron. It might be in the wire line that goes into the speaker. If not then the speakers or the circuitry inside is dead. Replace it.
If you do not want to replace it then try:
Go into your computer (in Windows), right-click the volume icon and click Playback Devices. Click on speakers (it should have a check mark on it), then click Properties. A box will open up. Click on Levels and click Balance, then check if the slider with an L is low or all the way to the left. If it is low then turn it up. If it is not then right click on the volume icon again, and this time click Open Volume Mixer. Hover your mouse over Speakers (or in some cases headphones) and you should see the brand (in my case it says VIA HD Audio). Go to the website and look for the latest audio driver for your PC/Laptop. Install it, and if it fixes the problem, GRET. If not, then replace the speakers, the left speaker is dead.
Or maybe it is not connected......check the connections.
Oct 26, 2016 | Audio Players & Recorders
No bass in righthand speaker
First try swapping the cables and put the left speaker cables in the right hand amp output and the right speaker in he left output. If the problem stays in the right hand speaker and does not move to the left as I suspect should, then it is a problem with your speaker crossovers. You may have to open up the speaker and check the wiring and then crossover. If the problem changes and appears in the left hand speaker you have an amp problem.
Jun 08, 2014 | Mission M73 Main / Stereo Speaker
Wich componet need to change if no sound for front left speaker no sound
check the speaker connection,check the speaker resistance,if it found ok.then open the av receiver top panel and check nearer component of left speaker connection.check the out put power ic .
May 24, 2014 | Sony STR-DE445 Receiver
Technics sl ch570
pls. try switching the speakers, if the sound switch from left to right or right to left , one of your speakers has an open circuit. check the wire for any open link or check the speaker for an open voice coil.
Jun 27, 2013 | Audio Players & Recorders
How can i open the case of the 2 speakers (BXR1221) because the left speaker is not working
It may not be the speaker, it can the left channel in the amp circuit this uses, The speakers can easily be tested to see if open or good with a ohm meter.
May 25, 2012 | Altec Lansing BXR1221 2 Speakers
Only two speaker are playing sounds
I'm using Windows 7 with Sound Blaster Audigy 2 and I had to; right click the speaker icon, left click "Playback devices", left click speakers, in lower left of box left click "Configure", then left click 5.1 surround. And of course there's more. Go into programs and open the Sound Blaster "Audio Console" and left click "CMSS 3D" and look under "CMSS Modes" , if OFF is listed in the box click on the down arrow and change it to CMSS. Now all speakers work just fine.
Sep 13, 2010 | Dell 5650 Computer Speakers
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
My left speaker doesn't work but my right speaker does. The cord to the left speaker is plugged in all the way.
Open the "Volume Control" applet & make sure the "Balance" setting is set in the middle of the scale. This way sound will go out through both speakers.
Nov 09, 2009 | Altec Lansing MX5020 Computer Speakers
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose...
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Jan 04, 2009 | Bose Acoustimass 15 System
Altec Lansing VS2621 Speakers Logo
267 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
