Question about Dryers
Error code f4 showing on tumble dryer TVFG85C but there is no pump fitted to the appliance
Error code F04 is showing, the fault code says ' dryer pump running when should be off' BUT there is NO pump fitted to this appliance so can you offer another solution please
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
  • 89 Answers
SOURCE: dryer stops & gets F04 code. ?? what is this code, can't find it in my book. Thanks LW
the F04 code refers to improper venting of the dryer.
either your vent is too long, or blocked by lint or a crimp.
dryer vents should be no longer than 10' in flexible venting or 15' in rigid venting.
alot you will find that at the EXIT port outside your house is clogged with lint. remove the lint and you should be ok.
Posted on May 26, 2009
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My tumble dryer (Bosch Exxcel) is showing an error
F09 error is no heating.
You can fix that by opening up the back and pressing the red cutout button which will restored hot air.
Good Luck,
I hope this helps
Posted on Nov 12, 2009
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Tip
    List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
    Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
    All this brands share parts, they share the same error code list, and the service is provided by same centres.
    I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
    Washing Machines and Washer Dryers
    • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
    • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
    • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
    • F13 - Check the water supply, inlet valve and hot and cold hose connections.
    • F14 - A fault with the water heating has occurred
    • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
    • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
    • F17 - Door not closed properly. Close door firmly at 3 o'clock position
    • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
    • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
    • F40 - Water below protection level during a heat step
    • F41 - Water level detect sequence incorrect
    • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
    Fault codes for LCD EVO1 Washers
    • F01 - Short circuit motor triac
    • F02 - Motor jammed tacho detached
    • F03 - Wash thermistor open/short circuit
    • F04 - Pressure switch jammed on empty
    • F05 - Pressure switch jammed on full
    • F06 - Program selector error
    • F07 - Heater relay stuck
    • F08 - Heater relay cannot be activated
    • F09 - Incompatible eeprom
    • F10 - Pressure switch not sensing correctly
    • F11 - Pump cannot be activated
    • F12 - Communication error
    • F13 - Dryer fan or dryer thermisotor fault
    • F14 - Dryer element fault
    • F15 - Dryer element relay fault
    • H20 - Not fillings. Check tap, hose and inlet valves
    • LOCKED - Check interlock
    Fault codes for LCD EVO2 and V4 Washers
    • F01 - Motor traic short circuit
    • F02 - Motor jammed or tacho detached
    • F05 - Pressure switch jammed on full - Check pump for blackages.
    • F08 - Heater relay stuck
    • F09 - Setup error
    • F12 - No communication between cards
    • F13 - Drying thermistor open/short circuit
    • F14 - Drying element faulty
    • F17 - Interlock error
    • F18 - Communication error
    • H20 - Not filling. Check tap, hose and inlet valves
    Fridges and Freezers
    • F1 - Freezer thermistor open circuit
    • F2 - Freezer thermistor short circuit
    • F3 - Fridge thermistor open circuit
    • F4 - Fridge thermistor short circuit
    • F7 - Evaporator thermistor open circuit
    • F8 - Evaporator thermistor short circuit
    • F9 - Temperature set switch open circuit
    • FA - No feedback from Baffle
    • FB - Fridge Baffle motor operating continuously
    • FE - Defrost time out
    Dishwashers
    • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
    • F11 - Heater timed out. The heater has not reached the required level.
    • F20 - Temperature under range
    • F21 - Temperature over range
    LCD Dishwasher Models
    • A01 - Float switch
    • A02 - Open/Short circuit heater relay
    • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
    • A04 - Unable to reach or sense temperature within 70 minutes
    • A05 - Pressure switch has not been reset
    • A07 - Open/Short circuit wash motor triac
    • A08 - Open/Short circuit auxiliary wash motor triac
    • A09 - Open/Short circuit with main wash traic
    • A10 - Open/Short circuit fill valve traic
    • A11 - Half load valve traic or alternating motor action
    • A12 - Open circuit heater rely
    • A13 - Open/Short circuit dispenser traic
    • A14 - Drain hose too low causing syphoning. Check drain hose.
    • H20 - Check tap and pressure of incoming water.
    Hotpoint Tumble Dryers
    • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
    • F2 - Thermistor or sensing circuit failure
    • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
    ...Follows--->
    on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
    After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
    Miele fault code f04 Ovens Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > fault code f04 > Ovens
    Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
    [PDF]USE & INSTALLATION MANUAL - Smeg
    www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
    Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
    [PDF]user manual e:line built in ovens - Appliances Online
    manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
    Jan 10, 2016 | Ovens
    Hot point tumble dryer toff 87c showing fault code f04
    Not sure bout the code. But if its turning off it may be due to ur cycling thermostat as per an over heating issue, check ur duct system and venting, u may also have a short in the heating element
    Jan 29, 2015 | Dryers
    I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
    These are the error codes : I hope it helps!
    f01 light 4, motor triac
    f02 light 3 motor, jammed/ tacho
    f03 lights 3&4 Ntc fault
    f04 light 2. pressure sw stuck on empty
    f05 lights 2&4, pressure sw stuck on full
    f06 lights 2&3, N/A?
    f07 lights 2&3&4 heater relay
    f08 light 1. heater relay
    f09 lights 1&4 eprom/setup error
    f10 lights 1&3, pressure switch not sensing
    f11 lights 1&3&4, pump/draining error
    f12 lights 1&2, communication error
    f13 lights 1&2&4, dryer ntc/ fan motor
    f14 lights 1&2&3, dryer heater
    f15 lights 1&2&3&4, dryer heater relay
    f16 N/A
    f17 light 4, door lock
    f18 light 3 comms error (3 phase motor) power board
    So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
    Nov 11, 2014 | Washing Machines
    What e54 error code mean on an electrolux dryer
    You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
    E54 - means the motor is inoperational.
    Could be:
    • Excessive wash load.
    • Voltage too low.
    • Motor/transmission system inoperative.
    Dado
    Aug 09, 2014 | Electrolux Dryers
    E64 error code electrolux dryer
    E64 - Heater thermostat
    • Thermostat faulty (replace heater unit)
    • Heater unit faulty
    • Wiring faulty
    • Electronic board faulty.
    Dado
    E03 error code
    Error Codes
    f16 N/A
    Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
    Dryers Logo
    26 people viewed this question
    Top Dryers Experts
