Question about IBM Lenovo ThinkPad L412 Notebook
Blurry screen the screen suddenly went blurry like there is a loose connection somewhere
Loggia Elite. Battery charge screen suddenly went black, scooter wouldn't work. External charger shows battery has full charge.
Check the battery connection at the battery posts. Look for corrosion on the battery as well.
Nov 26, 2016 | Health & Beauty
Philips soundbar the power went out suddenly have no idea hat happened
You may have blown out your speakers. Which can happen if your sound volume is too loud. Try looking at your connections, maybe a loose wire somewhere.
May 13, 2014 | Audio Players & Recorders
Screen ripples acer blurry
could be bad lcd or loose cable. youd need to call acer.
Jul 13, 2012 | Acer Aspire AZ1620-UR31P G530 All-In-One...
2000 Z3 2.0 Sudden onset misfiring with traction control light and EML light coming on. Happened as went over slight bump and noticed an odd smell ?burning which lasted a minute or so. Car starts fine but...
It sounds like you have a loose connection or wire somewhere, becuase you stated it started happening after you hit a bump which the jolt would cause movement in a component or wire causing some type of short or mis-connection to happen. I would check all wires, cables for loose or corroded connections, loose ground wires, especially battery and starter connections and tighten accordingly.
May 07, 2011 | 1998 BMW Z3 Roadster
Turn signals front and rear suddenly quit working . I went to get gas and they were working. when I turned the car back on after I got gas they did not work.
you have a loose, barely connection wire problem somewhere from fuse box to front and rear section of car. check fuses to see if one is loose, also, check fuse block is secure.
somewhere between there you will find your problem.
also check bulbs in sockets of the signals. making sure there is good connection.
Apr 16, 2011 | 1995 Toyota Tercel
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
There is a blurry dot on my LCD screen as well as on my photos
Well then, there's also a blurry dot inside of your lens somewhere, I'm not poking fun at this although it sounds that way. Try putting the whole cam in a bowl of ucooked rice for a 24 hour period, uncovered. Burry it deep. When you take it out shake any loose grains out that may have found their way in. Your blurry dot sounds like a moisture spot. The rice will draw all moisture out of the cam.
Aug 22, 2009 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Lens error and blurry photos
If your images are blurry and the lens wont move smoothly it is very probable that some kind of force on the lens has damaged a gear, barrel or even dislodged an element internally. When the lens detects an obstruction in its movement the camera reports accordingly,"lens error". You should have the camera checked by a service centre, it will most likely need the lens replaced as they are not serviceable.
Apr 14, 2009 | Canon PowerShot A630 Digital Camera
Blury screen with rainbow image cannot read words on screen
The convergence integrated circuits have failed and most likely the 2 5A fuses have opened as well. I would find a local Mitsubishi service shop.
Sep 28, 2008 | Mitsubishi WS-65908 TV
IBM Lenovo ThinkPad L412 Notebook Logo
24 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
