Question about Motorola CLS 1410 (4 Channels) 2-Way Radio
Motorola 1410 cls charging problems
The manual for Motorola CLS 1410 2-way radio does not say how to clean the radio and/or charger. How do I do this? Contact me at tlsiiitf@hotmail.com Thank You, Tommy S.
eradiostore
  • 1654 Answers
SOURCE: Motorola CLS 1450c radios microphone problem.
The problem you are experiencing is not a mic problem, or the problem would also be associated with the two-way radio portion of the radio. Your radio is either in need of repair or you have a bad, low or defective battery. It takes more energy to transmit or use the unit as a phone than to simply receive.
If your radio is under warranty (less than 1 yr old) you can return it to the place of purchase for warranty replacement or service. After warranty repair is also available through Motorola's factory depot. Ask your local dealer.
Posted on Feb 17, 2010
eradiostore
  • 1654 Answers
SOURCE: does a Motorola cls 1110 work with a motorola talkabout sx600R ??
It appears they do not have any frequencies in common.
Best regards.
SX series guide: http://www.banoggle.com/Products/Motorola/manuals/SX900-manual.pdf
CLS series guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
Posted on Mar 24, 2010
eradiostore
  • 1654 Answers
SOURCE: How do you set the channel and frequency for the
Here is a link to the manual: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find programming information on page 28.
Best regards.
Posted on May 05, 2010
eradiostore
  • 1654 Answers
SOURCE: i need the repair manual for motorola cls 1410
Sorry to say, there is no repair manual available for the CLS1410, nor are parts available, other than a few parts common to other radios. If you use the Motorola Repair Depot, they will replace your radio for the price of the repair (currently $116)
Best regards.
Posted on Nov 30, 2010
pctech1
  • 1940 Answers
SOURCE: How do you pair a
Motorola CLS1410:
To talk with someone on your two-way radio, the channel (CLS1410 only), frequency, and interference eliminator code must be the same on both radios.
Entering Programming Mode
  1. Press and hold Push to Talk and MON for 3 seconds while turning the radio on. The radio beeps and displays PROG, the channel number flashes, and the frequency (indicated by FREQ) and code (indicated by CODE) display alternately.
  2. Note: If you press and release the Push to Talk button when programming CSL1410 models, you will return to the front of the Programming Mode.
Selecting a Channel (CLS1410 Only)
  1. In programming mode, press MENU until the channel number flashes and the frequency and code display alternately (this is the first setting after you enter programming mode).
  2. Press - or + to select the channel.
  3. Press and hold Push to Talk to exit programming mode, or press MENU to continue programming.
Programming the Frequency
  1. In programming mode, press MENU until FREQ displays and the frequency number flashes.
  2. Press - or + to select the frequency.
  4. Note: See page 39 of the manual for information on frequencies for communicating with other business radios. If you are matching your CLS Series radio to an existing Spirit GT radio, see page 45 of the manual.
Here is your manual for the Motorola CLS1410: http://support.radioshack.com/support_electronics/doc71/71607.pdf
Motorola M-Series MU22CV:
To talk to others in your group, all radios must be set to the same channel and code.
To Change Frequency and Code Settings
1-CHANNEL MODELS
  1. Hold the Push-To-Talk button down while turning the radio on (turning the On/Off Volume knob at the top of the radio). The radio announces the current frequency setting. For example, it might say, "Frequency one."
  2. Press the Push-To-Talk button to scroll through frequencies. The radio announces each frequency as you scroll. For example, it might say, "Two...three...."
  3. Release the Push-To-Talk when you've reached the desired frequency.
  4. Press the Monitor button to select and save the new frequency setting. The radio announces the current code setting. For example, it might say, "Code two nine."
  5. Press the Push-To-Talk button to scroll through the codes. The radio announces each code as you scroll. For example, it might say, "three zero...three one..."
  6. Release the Push-To-Talk button when you've reached the desired code.
  7. Press the Monitor button to select and save the new code setting. The radio beeps to indicate that it has exited programming and is ready for use.
2- AND 4-CHANNEL MODELS
  1. Turn the Channel Selector knob to Channel 1
  2. Hold the Push-To-Talk button down while turning the radio on (turning the On/Off Volume knob at the top of the radio). The radio announces the current frequency setting for that channel. For example, it might say, "Frequency one."
  3. Press the Push-To-Talk button to scroll through the frequencies. The radio announces each frequency as you scroll. For example, it might say, "Two...three...."
  4. Release the Push-To-Talk when you've reached the desired frequency.
  5. Turn the Channel Selector knob to channel 2 and repeat steps 3 and 4. For the 4-channel models, repeat to set channels 3 and 4.
  6. Press the Monitor button to select and save the new frequency setting. The radio announces the current code setting. For example, it might say, "Code two nine."
  7. Press the Push-To-Talk button to scroll through the codes. The radio announces each code as you scroll. For example, it might say, "three zero...three one..."
  8. Release the Push-To-Talk button when you've reached the desired code.
  9. Press the Monitor button to select and save the new code setting. The radio beeps to indicate that it has exited programming and is ready for use.
Here is your manual for the Motorola M-Series MU22CV: http://www.blackbox.co.uk/documents/manuals/M/MU22CV%20Manual.pdf
Posted on May 19, 2011
Motorola cls 1410 on frequency 10 and need it to bw on 2
The manual can be found at:
http://www.axcesstechnologysource.com/manuals/cls_series_userguide.pdf
If you need replacements including a CLS replacement antenna, this place is great:
http://shopwiscomm.com/Motorola-CLS1110-CLS1410-C254041.aspx?sid=2181
Nov 22, 2013 | Motorola CLS 1410 (4 Channels) 2-Way Radio
How do you reset Motorola CLS 1410
The radio has fixed frequencies. If you wish to remove the options, they must be done individually for each channel. Here is a link to the manual: http://www.motorolasolutions.com/web/Business/Products/Two-way%20Radios/Portable%20Radios/CLS_Series_Radios/CLS%20Series%20User%20Guide.pdf
Jan 22, 2013 | Motorola CLS 1410 (4 Channels) 2-Way Radio
What are the frequencies for a motorola cls 1410 radio
Here's a link to the user guide for the CLS model radios. You will find the frequency list on pages 39-41.
Best regards.
Aug 04, 2012 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Can a Motorola CLS 1410 4 channel can be programmed that all 4 channels have the same operating frequency but different privacy tone on each different channel?
Yes. Put the radio in programming mode and walk though the programming steps. The Privacy Tone is referred to as CODE in the manual. Here is a link to the manual http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf. Programming instructions begin on page 28.
Best regards.
Oct 27, 2011 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I need the repair manual for motorola cls 1410
Best regards.
Nov 30, 2010 | Motorola CLS 1410 (4 Channels) 2-Way Radio
How to change frequency on the cls 1410
Here is a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find basic programming instructions on page 28.
Best regards.
Apr 19, 2010 | Motorola CLS 1410 (4 Channels) 2-Way Radio
User's guide
A User's Manual for Motorola CLS series is available online here.
It's file name is Motorola CLS Manual (PDF).
You would need Adobe® Reader® to view PDFs.
Good luck and kind regards.
Dec 29, 2007 | Radio Communications
Motorola CLS 1410 (4 Channels) 2-Way Radio Logo
35 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
