Turn bios mode acer aspire 7535g
My laptop keeps shutting down while in use does any one have a remedy
SOURCE: acer aspire one model ZG5 does not boot
After a normal restart yesterday, my Aspire One booted into just a black screen. No POST, no BIOS, no hard drive light activity, just the power button LED on and the fan running fast. I was not very happy…
I went to the Acer Aspire One User Forum and started looking thru the Hardware section. I found this thread Dead aspire one and it looked like many others had a similar experience. After reading many stories of warranty repair or replacement, I was just about to dig up my receipts when I found this post: Re: Dead aspire one.
It seems that a lot of people had success reflashing the BIOS from a USB drive using tools provided by Acer. I don’t know if it’s officially supported by Acer or if it will void your warranty, but if the computer’s a paperweight now anyway, what the hell?
It’s very easy to do, but the steps are a bit unclear so here’s my attempt to make the whole thing painless. This worked for me, but it might not for you, so do this at your own risk.
You need:
A working USB thumbdrive you can erase. I used an old 64meg.
UNetbootin. Download from here: http://unetbootin.sourceforge.net/
The files to flash the BIOS. I used the most recent version from here: http://sites.google.com/site/maclesblogspotcom/
Download all the files to an easy to find location.
Steps to prepare the USB drive:
Format the USB drive using the FAT file system, not FAT32.
Start UNetbootin and choose FreeDOS as the distribution. Screenshot here.
Unzip the BIOS files and copy them to the USB drive
Make a copy of the BIOS file and rename it as ZG5IA32.FD (this appears to be very important - my reflash failed until I did the copy & rename)
Reflash the BIOS:
Make sure the AAO is turned off, the battery is attached and the power adaptor is plugged in.
Insert the USB drive
Press and hold FN + ESC and press the power button to turn it on. Release the Fn & ESC keys. The LED in the power button will flash.
Press the power button again once and wait. Mine took ~3 minutes, but I’d advise that you let it sit there for at least 5 minutes just in case your’s takes longer.
When the reflashing is done, the AAO will reboot and, hopefully, you’ll be back to normal.
If it doesn’t work, try reflashing again. The keypress sequence is a little tricky.
If the second try doesn’t work, then you’ll probably have to send it off for repair.
Good luck!!!
http://chromick.com/eric/aa1/aspire-one-black-screen-of-death/
Posted on May 13, 2009
ckuzkuz
  • 255 Answers
SOURCE: My Acer One Aspire is stuck in hibernate.
This solution may sound stupid, but it is affective. Try to press really long time (about 1-2 minutes) on the power button of the laptop. wait for it to shut down completely. Then turn it on to see what happens.
What may have caused this is an update of any sort.
Posted on Nov 11, 2009
lserni
  • 466 Answers
SOURCE: ACER Aspire 7535G, can't get the bluetooth to work.
First of all check that you really DO have a BlueTooth unit. Acer uses the same chassis for models with and without Bluetooth, so the button being there doesn't mean necessarily there's something under it.
For example this one 7535G on eBay does not have a BlueTooth.
http://cgi.ebay.it/NOTEBOOK-ACER-7535G-824G25MN-250-GB-4-GB-LX.PCE0X.086_W0QQitemZ230389757718QQcmdZViewItemQQimsxZ20091019?IMSfp=TL091019235001r2963
If you do have bluetooth:
Check the Bluetooth is active in the BIOS, and if you have a single button model ("one button to rule them all") check the button configuration - there should be an Acer hotkey utility somewhere to do that. Very often, the button is set to control only one device between WiFi, optional internal cell modem, and BlueTooth. Normally that is WiFi. Set it to "Both". This, I repeat, if you DO have a 'single button' device.
Also, check you have the original Acer drivers. I once mis-installed a set of wrong Widcomm drivers without realizing it, and almost went crazy troubleshooting it.
Posted on Nov 12, 2009
  • 1481 Answers
SOURCE: Bios laptop Acer Aspire 1360 is empty / broken after wrong flash
how come ur BIOS is empty....
did u FLASH ur BIOS with any firmware update....
Posted on Dec 20, 2009
  • 10406 Answers
SOURCE: laptop shuts down
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job", to remove the dust, because the dust is acting as a layer of insulation, trapping heat inside your computer.
Reload the battery.
Connect the AC power.
Start your laptop, and check that the fans inside the notebook computer are pushing air out of the exhaust-vents. If not, the fan(s) have failed, and you need a professional computer technician to disassemble your computer, and fix the fans.
Posted on Jul 16, 2010
My aser aspire say the oprating system not found but the hard disk has the oprating system and ot works properly what can i do to fix this and how can i enter in bios mode
Shut down your Acer Aspire if it is running. Once the computer is off, press the power button to start it. Press "F2" immediately while your computer is booting up and displaying the "Acer" logo. Keep pressing "F2" until the BIOS Setup screen appears.
Aug 16, 2016 | Aspire Computers & Internet
Can't boot system shuts down immediately
The hard drive has failed and needs replacement.
Feb 23, 2014 | Acer Aspire 5742Z-4200 Notebook
Fn key not working on Acer 7535g
Hi it may be due to malfunction of the keyboard, try to change to a new keyboard from Acer Technical Centre, I'm sure it will work.
Oct 27, 2013 | Acer Brand 17.3 WXGA++ Glossy Laptop...
Clear bios pass word on acer 7535g
Go here and download the Service Guide for that unit. Then go to Page 116 (in Chapter 5) for instructions regarding clearing of the BIOS Password, or to Page 40 (in Chapter 2) for instruction on clearing the HDD Password.
Oct 04, 2012 | Acer Aspire Computers & Internet
Acre aspire keeps shutting down
it is XP, right? you need to setting the BIOS
Jun 23, 2012 | Acer Aspire 7520-5757 Notebook
My brand new acer aspire 5515 laptop keeps shutting down
Return it for service. This is a defect. The fan should run until the heat is below the temp threshold.
Jan 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
Nov 12, 2009 | Acer Computers & Internet
Acer aspire 5610-4654 keeps shutting down
Did you noticed overheating (hot laptop areas, fans spinning like in crazy?)
Can you start the laptop again just after it shuts down itself??
Jan 18, 2009 | Acer Aspire 5610-4648 Notebook
My Acer Aspire 5630 shuts down by itself after about 10 minutes when I am on skype
I think the first thing you should check in the power save, Down by the clock, i know you can change how long your laptop is on to save power plugged in or on battery
Nov 30, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
David Payne
David Payne
