Question about Cameras
Cyber shot n50
How to change iso values... ??
RehanZafar
  • 38 Answers
SOURCE: How to change language display on Sony Cyber-shot
Start of Automatic Adjustment Program
Double-click the application file (DSC-T700 Auto-Adj
Ver_1.0r01.exe), and the Automatic Adjustment Program will start.
DESTINATION DATA WRITE
Note:
The DESTINATION DATA WRITE cannot be set with other
than the Service board.
1. Function of Each Button on Destination Data Write
Screen
Click the [DESTINATION DATA WRITE] button on the Main Menu
screen, and the “DESTNATION DATA WRITE” screen in Fig. 6-
1-10 will appear.
Fig. 6-1-10
1 [To Menu] button
Return to the main menu.
2 Destination Check button
Current destination setting checked when the “DESTINATION
DATA WRITE” screen started is displayed.
When this button is clicked, the destination is checked and the
display is updated.
3 Destination List
Select the written destination.
4 [Data Write] button
Write the destination data to the camera.
Japanese
English
French
German
Spanish
Italian
Portuguese
Simplified
Chinese
Traditional
Chinese
Dutch
Russian
Korean
Persian
Arabic
Thai
Melayu
Swedish
Norwegian
Danish
Finnish
Polish
Czech
Hungarian
Turkish
Greek
J1 J z NTSC
JE3 JE z a a a a a a a a a a PAL
U2 US z a a a a a NTSC
CA2 CND z a a a a a NTSC
CEE2 a a a a a a a z a a a a a a a a a PAL
CEE8 z a a a a a a a a a a a a a a a PAL
CEE9 z a a a a a a a a a a a a a a a a PAL
CEH UK z a a a a a a a a a a a a a a a PAL
E15 z a a a a a a a a a a PAL
E32 z a a a a a a a a a a PAL
E33 a a z a a a a a a a a NTSC
TH6 Thai a a a a a a a a a z a PAL
AR2 AR a a z a a a a a a a a NTSC
AU2 AUS z a a a a a PAL
HK1 HK z a a a a a a a a a a PAL
CN2 CH a a a a z a a a a a a PAL
KR2 KR a a a a a a z a a a a NTSC
BR1 BR a a a z a a a a a a a NTSC
z: INITIAL LANGUAGE
E
DESTINATION
VIDEO OUT
Default
AEP
AREA
SELECTABLE LANGUAGE
Posted on Jul 26, 2009
BillB-SA
  • 2761 Answers
SOURCE: TURN CAMERA ON SCREEN FLASHES cYBER-sHOT AND GOES
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Oct 13, 2009
Kensolutions
  • 455 Answers
SOURCE: When powering up my cyber-shot
The exact steps can be provided with the correct model #. The model # starts with "D". Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Posted on Oct 21, 2010
SOURCE: Could you tell me how to reset my Sony Cyber-shot
my camera is recording problem.
Posted on Oct 31, 2010
Rammsteins
  • 300 Answers
SOURCE: Change language display on Sony Cyber-shot DSC-W220
The region has to be changed to US or UK. It is done with a special Sony adjustment software.
Posted on Mar 05, 2011
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
What is EV on the menu
Hi cute_chic24,
EV is Exposure value refers to the amount of light for a given exposure. It is denoted as a single number. Its value is subsequently used to calculate the correct combination of shutter speed and aperture at a given ISO speed of the sensor.
Starting point is a shutter speed of 1 second at f1, which is denoted as EV 0. Further up the scale a single exposure of EV13 could be ISO 100, f8 - 1/125s, or f11 - 1/60s.
It doesn't make any difference which combination you choose, as all variations at the same EV will ensure a correct exposure. Remember though, you are always balancing camera or subject movement against depth of field. This is because a change in aperture will require a change in shutter speed for an equal amount of light to reach the sensor or CCD. If you set the shutter speed one stop slower and aperture one stop smaller, exposure doesn't change, but you increase depth of field slightly and the possibility of blur.
ERNZ
Feb 03, 2010 | Sony Cyber-Shot DSC-L1 Digital Camera
Sony cyber shot dsc-t70 unable to change flash setting
The Flash Off setting is fixed and cannot be changed if you are using one of the following modes:
  • High Sensitivity, Twilight or Fireworks Scene Selection
  • Burst or Exposure Bracket REC Mode
If you are using one of the above modes, change the setting to regain flash control.
NOTE: If using Scene Selection modes, the ISO setting is also fixed to ISO AUTO .
Aug 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
How to change the ISO ?
RESET camera by going in camera Menu and select INITIALIZE and press OK.
Apr 09, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
GRAINY PICTURES
Noisy pictures = High ISO in almost all cases. Select ISO manually (select a manual mode where you can control the ISO) and set it to the lowest possible value. To avoid camera shake, place the camera on a tripod or another sturdy surface; or use the flash
Dec 20, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Need Help with the F717
Are you set at green program mode on the dial? Nightmode doesn't fuction on A or S or manual mode.
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
F505v ISO
You really can't change the ISO, but you do have some control over it, by being aware of how the program AE modes affect the camera's ISO settings.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
