Vacuums Logo
A
Anonymous Posted on Jul 26, 2013
Hi. I have a Hoover SM1901 "Pets" and the foot "switch on" pedal is now not working. Is this easy to fix/repair?
2 Related Answers
Anonymous
  • 35 Answers
  • Posted on Dec 21, 2008
SOURCE: Wiring foot pedal switch legend II
If I remember correctly,on the switch itself,each connector is letter coded.'W' for white,'R' for red,and so forth.The manual mostly talks about how to change attachments and basic operating,but not repairs.
small6363
  • 18429 Answers
  • Posted on Dec 11, 2012
SOURCE: In trying to repair foot pedal on my Hoover Windtunnel self propelled bagged vacuum, I got carried away and took apart most of the unit and I am still not able to get to the release..... I need help f
this video should help you
Testimonial: "Thank you! I will try it."
2answers
My Hoover WindTunnel brush engagement pedal's spring
We are Fixya, we aren't Hoover. You need to contact them direct or take it to a local Vacuum Cleaner repair shop.
There are parts schematics in this link. Parts 30 and 31.
https://www.google.com/search?q=hoover+uh30301+parts+schematic
Why does my Hoover Wind tunnel not standing upright? I know it's not the foot pedal. Is it a crack in the base or somewhere else? This happens frequently. I've had it fixed several times.
If the pedal is good it may be the base itself that is flexing or broken. Inspect it carefully to determine where or why it is not holding properly.
The pedal on my hoover is stuck
Your foot pedal is likely not snapped on to the axle assembly all of the way.
1helpful
Power switch doesn't work
so replace the power switch you can get one at guarantee vacuum and sewing center
Loss of suction
Hi Dan,
I've just replied to your previous question - however, due to the further information you've supplied here, I'd encourage you to call our Helpline, so we can run through some troubleshooting with you to resolve this issue. Our Helpline number is 0800 298 0298 - please have the machine to hand when you call.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
My hoover wind tunnel self propelled vacuum wont stand up be itself. The locking thing is not working. Thank You. [email protected]
If you look at the foot pedal, see if it is locked in the base, and pivots freely. I have seen some of these that break the base, or break the spring hinge on the back side of the release pedal.
2helpful
2answers
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
3helpful
VACUUM REPAIR
There are 2 tabs that stick out on the release, they fit in slots, so from the top look down and you can see them, using a flatblade screwdriver that will fit in there, push the side in to release it, which isn't easy, but it can be done. When you get the old one out, then the new one, push down on it until it locks into place.
Mar 06, 2008 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
