Whirlpool whitemagic 123 650p
When power ON the machine all LED,s are blinking and "tik tik" sound only what will be the issue?
  • 833 Answers
SOURCE: water is not flowing into the machine
There are a couple of possibilities:
  1. Are the hot and cold valves open?
  2. If there are filter screens in the lines, are they clogged?
  3. If set to warm, does any water flow at all?
  4. If there is no water flow, first check the water level switch to see if it is working...this is located on the bottom of the machine...it is generally round and has a tube running to the tub and two or more wires.  It should have closed contacts to let the water valve work.
  5. If there is some water flow, the valve is likely bad or the supply is clogged.
  6. If the switch is continuous, the problem may be the timer.
  7. Is the water temp switch good?...unlikely.
Posted on Dec 12, 2008
  • 298 Answers
SOURCE: I want user mannual of
you can try and go to (appliancerepairplanet.vstore.ca to see if they can get it for you.
Posted on Dec 17, 2010
  • 273 Answers
SOURCE: In Maharashtra, India where
Ask by e-mail:
helpdeskindia@whirlpool.com
Whirlpool of India Service locator website:
http://www.whirlpoolindia.com/servicecenter.aspx
Also:
http://www.customercareinfo.in/whirlpool-washing-machine-service-centre-phone-number-india.html
Good luck from Detroit, MI, USA.
Posted on Mar 02, 2011
SOURCE: i have whitemagic f55 model
hi i am deepak my whirlpool whitemagic f55 low voltage problem plz help
Posted on Jun 16, 2011
caroldon
  • 17129 Answers
SOURCE: my whirlpool whitemagic washing machine top panel board doesnt work or no power?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If there is no power check the outlet and mains wire. If not the control board is a suspect., check the door switch which needs to close for the program to activate.
Posted on Feb 28, 2013
Whirlpool Washing Machine Whitemagic h70 Wiring Diagram
Can't seem to find one.
Is there a model# other than whitemagic h70?
I have had luck on parts places showing schematics when you start looking for parts in the machine.
Maybe that can work for you.
Nov 25, 2015 | Whirlpool Washing Machines
Beep sound with led glowing in wash options in whirlpool 650p whitemagic.what is the problem
Please check your owner's manual. Look for troubleshooting.
If no answers, look for customer service number, they may be able to help. You may be able to find answer by Google your brand and model. Other people may have had the same problem and found answers.
Feb 18, 2015 | Whirlpool Washing Machines
Pe ERROR WITH WHIRLPOOL MAKE WHITEMAGIC 123 650 h WASHING MACHINE, MACHINE WORKS BUT OUTER BOWL DOESNOT SPIN AND MAKING BEEP SOUND DURING PROGRAMMED
does tube move by hand? does it have the correct amount of resistance when turning, or is it hard or too easy?
Dec 09, 2014 | Whirlpool Washing Machines
I have 42" Daewoo LCD, after one and half year of use, once i start the main power connection the lcd's standby red light blinks for 2 minutes thn becomes stable.. Once it become stable a tik
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 29, 2014 | Televison & Video
Whirlpool whitemagic pro 700h
The model no is Whirpool whitemagic pro 700H fully automatic top load
Dec 19, 2013 | Washing Machines
My lg monitor having tik tik sound from chopper transformer and blinking the led, after some time a smell coming
It's getting fried. Maybe it is grounded. Get it checked by a technician. It might cause fire.
David
Jul 06, 2013 | Computers & Internet
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I have panasonic TV topdom when I on the tv then there is no picture but there is tik tik sound coming continuouly and led is blinking fastly.if u have solution then guide me thanks
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope that this will workout....
Jun 13, 2011 | Televison & Video
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
