Fix error L4 in sharp AL 2020 - Office Equipment & Supplies
2 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Posted on Jun 01, 2010
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
What is an error code L4-11 on a Sharp AL-M162 All-in-one?
When your copier problem on main motor then show L4.
Solve: 1.Check all gear in motor section.
2. Check main motor fuse
3.Mechanical section any gear was broken.
Dec 15, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp ar -m351 Error codes L4-30
sharp printer mx-m450n error code l4-02
Nov 24, 2009 | Sharp AR-M450N Copier
Have an AL-1000. got a crunching noise on start.error message flashes L4..motor drive error?
You most likely have a problem with your fuser rachet dive gear or it could be the upper fixing roller drive gear. I would first look to see if any of screws are lose that hold the fuser in. It could be just from wary and tary on the fuser or it could be that the lower fixing roller is damaged. If your copier has over 50k on it may just be easier to replace the whole fixing unit. Good Luck
Aug 10, 2009 | Sharp AL-1000 Copier
Sharps AL 1530CS flashing L service code and shuts down
You didn't mention the number or code or L code.
If its L1-00 its just only the scanner, it means the scanner is locked.
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Feb 23, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Sharp AL-1217
L4-1 Main motor problem
Aug 10, 2008 | Sharp AL-1217 Copier
L4 Code
you have to unlock the machine from the bottom part of the scanner there is a littler lever .if the lever is unlocked try with the folowing this take off the glass then clean and lubricate the shaft
where the carriage is back and fork
Nov 09, 2007 | Sharp AL-1641CS Laser Digital Copier
46 people viewed this question
k24674
jasbo
jasbo
