Question about Dryers
Wed6200sw1 loud screeching sound when i first turn it on..
Why does my john deer la115 make a loud screeching sound when i take my foot off the brake
Bad belt or belt tensioner. Shut it off and look underneath for problems.
Apr 21, 2012 | John Deere Garden
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Monitor makes loud screeching vacuum sound; no screen display..?
check to make sure that there arent any magnets near or around it
Apr 13, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Loud Screeching sound When Turning only on occassion.
it sounds like the power steering belt is loose. If it has a tensioner pulley the spring in it might be loosing it's tensile strength. While you are looking at the belt pay attention to the side that is against the pulley to see if it has alot of cracks. If it has I think 10 cracks per inch that is too much and needs to be replaced.
Dec 31, 2008 | 2000 Hyundai Accent
Dryers Logo
18 people viewed this question
Top Dryers Experts
