Question about Lands Phones
Nitsuko tx series tx 308
There is a buzzing noise when I lift receiver & this continues through to when speaking . Can you advise how to fix ?
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: loud buzzing when amp connects to guitar
The buzzing noise could be caused by a grould feedback loop. This occures when the amp is plugged into one power socket and the guitar's amp is plugged into a drifferent power socket.
Try to use a power board, plug in all your devices into this power board and plug the power board into a power socket.
Posted on Jan 03, 2009
freetek
  • 5568 Answers
SOURCE: Onkyo tx-sr606 receiver buzz
This kind of noise can be caused by a transformer that was poorly made. Iron core transformers are normally 'potted' in a vacuum so that epoxy (or lacquer) is forced into the laminations to prevent them from trying to vibrate with the line frequency.
If you are adventurous, remove the housing, turn on the power and using an insulating probe such as a plastic rod (a plastic picnic knife will work), place the tip of it on any larger parts you see and place the other end behind your ear. This will carry the sound in a more directional manner to your ear. You should be able to locate the source of the buzz.
If you can, and it turns out to be a transformer, it will probably have a metal shield around it so it might not be possible to gain access to the laminations. If the shield isn't ultra tight, you might be able to flow some 'Super Glue' into the cracks and with luck, 'glue' the laminations together. Super Glue (or equivalent) is a good insulator so will not cause any electrical problems but take care not to get it on any plastics that are exposed with the housing on, it will cloud them forever.
Posted on Feb 27, 2010
Grubhead
  • 5056 Answers
SOURCE: I have an Onkyo TX-SR806 receiver, that won't play
Don't know if it applies to your model but on my 607 it says Zone 2 won't work if Bi-amp is being used!
Posted on Jun 14, 2010
Why my nitsuko tx serise nxe2464m tx extension phones are not riging
Ringing is assigned in system programming, either a tech or your office in house tech will need to make the change.
Jul 03, 2014 | NEC Dterm DTP 16D-1 Corded Phone
I get a buzzing noise when my thunderverb 200 is idling
turn on the ground lift and/or make sure the unit is properly grounded
May 27, 2011 | Orange Amps Orange Amplifiers Thunderverb...
Hello. I have Onkyo tx-sr606 home theater
could be a bad soldered joint or loose connector, even a bad earth in the secondary power circuit.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
My nitsuko old model phon with pbx system want to reprogram, pls advise sakir ahmed
I am looking telephone set for nitsuko model 206G for purchasing or another model telephone set can be use
Nov 10, 2009 | NEC PT-390 /NITSUKO Phone
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Buzzing/vibration noise from ONYKO TX-SR506 unit
If the unit is under warranty, DO NOT open it up. Bring it in for an exchange or warranty service. Explain that the unit makes noise during use and it will be serviced. This could be as simple as a bad connection in the power supply area and you are hearing oscillations or it could be a defective power transformer. Either case will be covered under warranty so there should be no charge to you.
Keep us posted.
Dan
Feb 17, 2009 | Onkyo TX-SR506 Receiver
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Lands Phones Logo
50 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
