The error code is displayed when its beeping. I don't know the error code, so It can only be three things, Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below. Add up the lights that are on.
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
take the motor shroud with the magnets in it off you will probably find corrosion on the terminals on the small circuit board clean it off, whilst you are at it check your pump is spinning freely if not pull it off and dismantle it clean the rotor it may have a rust buildup on it, when putting it back together give the bearing holder a few taps to centre the shaft before you tighten the screws completely, if it tightens up when you tighten the screws give it another couple of taps either side of the bearings until it frees up
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
The out of balance micro-switch is faulty/corroded. This switch is located under the motor control module on the right of the machine and is activated by a plastic lever that goes down beside the outer tub. Replace the micro-switch.
