My w10304136e whirlpool dose not lock the door and not start
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Sep 28, 2015 | Whirlpool Washing Machines
Drive side power door lock is not working
If the door lock works ok with a key, I would say the lock actuator is failing. Its a small electric solenoid that moves the lock rod.
Jun 26, 2012 | 2008 Hyundai Veracruz
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
My security remote dose not work
Hello, It seems as is if you have a remote that will not lock the doors all the time. There can be a couple of reasons that it wont work at times.1 it may have a weak battery,2 there may be some kind of residue inside the key fob itself such as tea,coke,water, or even sweat. This will short the fob out at times.Thank you
Feb 22, 2009 | 2005 Buick LaCrosse
Trying to find out how to lock the door on the whirlpool designer
The door latch mechanism is defective. It is self-latching.
The door latch switch must be replaced.
Feb 21, 2009 | Whirlpool RBS275PD Electric Single Oven
Dryer starts on it's own - won't shut off
TRY DISCONNECTING THE START BUTTON WIRES AND SEE WHAT IT DOSE WITH THE DOOR CLOSED,IF IT DOES NOT START IT YOUR START SWITCH-MIKE
Feb 16, 2009 | Whirlpool LER5636P Electric Dryer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
