Question about Vacuums
How do I take apart the cyclone for the cyclonic Hoover? Uh70070, I would like to clean it.
  • Vacuums Master
  • 18,424 Answers
Posted on Jul 27, 2013
2 Suggested Answers
  • 97 Answers
SOURCE: Overheating Hoover
Most likely caused by a lack of airflow. Check to see if you have airflow at the end of the hose. If not, Remove all of the hoses and ensure that they are not clogged. If there is airflow through the hose; check the air inlet immediately aft of the brushroll, inside the nozzle. This is a very common place for clogs to form.
Also note: contrary to some manufacturers claims, you can not clean (or wash, for that matter;) a hepa filter. The small particles are too embedded in the filter media to ever get completely removed, and the act of cleaning tends to damage the filters, even if you can't see the damage. This is why bagless life-spans, on average, are half the length of the life-spans of bagged vacuums.
Good luck,
-R
Posted on Aug 01, 2008
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
Power just stopped working
It may be chance but I would locate the air filter, if very dirty it will cause the motor to heat up and trip a thermal breaker, last one I saw we had to wait several hours for the breaker to release.
Needless to say when I washed per the instructions on the filter the water ran black for several minutes, had to let it dry overnight and not use air or heat directly on it.
Most that can be washed are foam and have instructions of some sort where the filter installs.
hope you have that and not a electrical failure in the unit.
Dec 11, 2012 | Hoover UH70070 Bagless Upright Cyclonic...
How do i clean my dyson root cyclone vacuum cleaner
believe it or not i would use a long paint brush with a opened bin linner,, to collect all the dust,,,
you can wash your blue filter in plain water and leave to dry as u would pots n pans on the side,,
when u have cleaned the area around the cyclone.. close your eyes and blow into the cyclone.. then use another large hoover to remove access dust and rubbish that was in the cyclone,
hope this helps reguards lee.
May 01, 2010 | Dyson DC16 Root 6 Bagless Handheld...
How do you clean the Dyson dco7 cyclone top
Hi its Darran at Dyson.
We would not recommend that you take the cyclone top apart. This part is designed to be a sealed unit and taking it apart may affect ther performance of your machine ongoing.
If you are concerned with the performance of your machine, please follow the blockage procedure and filter washing instructions on our website in the support section at www.dyson.com or check your user guide.
If you do want to clear dust and debris from the cyclone, we recommend that you simply hold the cyclone top over a bin and bang the sides gently to remove any dust from the inside.
Kind regards
Darran
Dyson Customer Service
Mar 16, 2010 | Dyson DC07 All Floors Bagless Upright...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover savvy will not move
the reset button is in the handle, under the cover for the switch. remove the two screws and pop apart. you need to pull up the little post under the lever switch, and push it back down. hope this works for ya.
Jul 01, 2009 | Hoover U8145-900 Savvy Bagless Upright...
It shut off and will not restart
All the filters have to be removed and cleaned or replaced
Apr 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Vacuums Logo
69 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
