Question about Garden
Homelite trimmer hlt25css
Pull cord has come of pulley want to know how to put it back on please
  • 413 Answers
SOURCE: Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
Posted on Mar 28, 2009
  • 4 Answers
SOURCE: Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
Posted on May 25, 2009
steve_lima
  • 181 Answers
SOURCE: Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Posted on Jun 02, 2009
  • 6 Answers
SOURCE: st185 Homelite string trimmer starts then dies
I resolved my problem by taking apart the carborator and cleaning it. There were clogged passaged that had stuff come out of them when I used airisol carb cleaner to blow them out. I only had to make one gasket the carb mount gasket which is pretty basic only 5 holes.
It ran for the next 3 hours, ran fantastic!!!!!!
Posted on Jun 14, 2009
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Posted on Jul 25, 2009
Replace Pull cord poulan p3500
Hook the cord into the small cut a way in the side of the pulley, now wind the pulley in a clockwse direction you should feel the the spring tention increasing, once there is adiquate tention unhook the rope from the pulley and allow the spring to wind the pulley back and pull the cord in, do not forget to replace the screw and plate that secures the pulley as it appears to be missing on your video.
May 26, 2013 | Garden
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
Gentlemen, I have a Mighty lite Trimmer of which the cord does not recoil. It appeares that the heavy torsion spring bends when cord is pulled and cord stays out instead of recoiling. Where can I get...
I have the same problem....the cord remains out...so I pulled it apart and discovered that the recoil wheel that the cord rewinds onto does not stay where it is supposed to and rides upward catching on the fixings that hold it in place. When i pressed it down the cord retratcts immediatley. Only problem is it does not stay there. It was only used three times.
It has everything to do with being a cheap product. I should have paid a little more and bought a better product. Will not buy homelite again.
Aug 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite weedeater pull cord wont retract once ive pulled on it to start
you will need to remove starter cover & boom assy ,
sounds like either the rewind spring is broken or the pulley has split at the base of pulley or the starter pawls are bent / jamming , check that the centre pivot if this unit uses this type is not binding , pulley should be free , check the pulley is not damaged ?
either way once cover is off you should be able to see the problem
check the lugs that secure the pulley to the cover if unit has 3 lugs that secure to the cover ?
replacement parts should be available reassemble and test
cheers hope it helps paul
Jul 17, 2010 | Homelite Mighty Lite Lawn Trimmer
The pull cord on my homelite weedeater is jamming and not able to pull it all the way... can't see anything that is jamming it and does not appear broken.
Sounds like the cord is caught in a slot on the side of the pulley the rope recoils into. The cover will have to be removed and maybe some additional things but it can be fixed fairly easy with some patience.
Jun 09, 2010 | Homelite Garden
Hard to start and keep running
By "pulley assembly" I assume you're talking about the recoil on the starter cord. You can check E-Bay. I just did. There was one for $15.00. But I don't know if it'll fit your model. PLEASE rate my answer.
Sep 04, 2009 | Homelite Mighty Lite Lawn Trimmer
Gas weed eater pull cord wont retract after pulling cord
Jul 25, 2009 | Garden
Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
Jul 22, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
I cant start it due to the pull cord not coming out further than 5-6 inches??
Sounds like the cord may be wrapped outside of the recoil pulley and may be spinning the motor backwards. The cord can backlash especially if the trimmer kicked a bit during starting.
Apr 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Mar 25, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
