Question about Bose MediaMate Computer Speakers
I have a pair of Bose MediaMate Computer Speakers, the one with the volume control has stop working. nothing was spilled on it and to my knowledge it wasn't dropped. My question is : How do you open u
Serial # 031095Z52440963BP
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
  • 5 Answers
SOURCE: Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Posted on Jan 02, 2009
SOURCE: Bose Companion 3 Series II speakers volume problem with Adapter
use 220 volts , 50 watts
Posted on Aug 06, 2009
fixyathing
  • 341 Answers
SOURCE: Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Posted on Aug 12, 2009
hakimmadina_
  • 155 Answers
SOURCE: MY BOSE COMPANION 2 COMPUTER SPEAKERS STOPPED
The coil inside the speaker is very tiny and if it loosens contact to main line to the jack, it may have open or short wirings inside. Or that one of the lines have shortages. If you can use a voltmeter tester, you can check if it has open or short wirings. If it's just both, then you can change the wire from the speaker to the jack. But if it stills hums, then there must be loose connection inside the speaker, so you need to replace the speaker with the same wattage and diameter available in electronics stores.
Thanks.
Blessings.
Posted on Dec 12, 2009
The driver for our bose speakers suddenly is not working. We uninstalled the driver but the computer is saying it has found a driver but ran into an error in downloading it. What next?
if your computer came with a motherboard disk the drivers could be on it
control panel sounds and audio,volume you can adjust the volume or advanced,speakers ((select appropriate speakers)) or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 02, 2011 | Bose MediaMate Computer Speakers
Installed the speakers into my new Desktop computer.I cannot obtain any sound now from the speakers. They appear to be installed properly.
make sure your master volume is not on mute or try plugging the speakers into the other jack on the back of the computer.
Nov 25, 2010 | Bose MediaMate Computer Speakers
My computer speakers don't work! Normally, when I plug headphones in they work ,but otherwise they don't. I use Bose Mediamate Computer System speakers and run on Window's Vista.
control panel sounds and audio devices volume there might be a tick in the mute box untick or select advanced on the bottom next to speaker volume from the drop down list and make sure you have selected the right speakers
hope this helps
Nov 04, 2010 | Audio Players & Recorders
No sound on my computer. it was working until two days ago.
u don't need to restore it's dound setting problem iu just chek volume control and chek master sound and wave sound is on or mexmimum
Jan 08, 2009 | Bose MediaMate Computer Speakers
Bose media mate speakers suddenly don't work after ....
what type of computer? desktop or laptop? have you changed or added a sound-card?
Jun 24, 2008 | Bose MediaMate Computer Speakers
Speekers
ok so the problem is with the speakers volume control variable resistor,,,,
just open the case of the speakers and change the variable..
you can see the rating of the variable in OHMS.... and replace the resistor
Dec 15, 2007 | Bose MediaMate Computer Speakers
Bose MediaMate Computer Speakers Logo
120 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
