Question about Sharp AR-5316 Advanced Digital Imager Copier
Trouble shoot my copier
My copier has a problem is blinking L1
  • 2 more comments
  • JOHNWSC Nov 17, 2007
    HAVE THE SAME PROBLEM AND THE HEAD LOCKING SWITCH IS UNLOCKED.
  • JOHNWSC Dec 04, 2007
    Everything is on track. I tightened the belt because it was skipping. the copier tries to cycle, the scanner moves slightly then strains. It then stops and flashes L1. In order to try it again, you have to turn power off then back on. I have 2 of these copiers with the same problem.
  • Anonymous Aug 06, 2008
    BLINKING L1 WONT COPY, WHAT TO DO?
  • Anonymous Aug 07, 2008
    I keep getting a blinking ch on machine
My copier display m2..... what is meant by that?............help
mj
Posted on Jan 10, 2008
    Sniper:
  • 71 Answers
Already answered on previous post.
Posted on Aug 30, 2007
  • 4 Answers
L1 is a code that occurs when the mirror/lens assembly has a problem. Most times the problem can be found when the glass is removed and while unplugged, checking that the lens is on track under that black tin cover. This generally happens when the copier is moved and the scanner jumps track, a ratt a tatt tatt noise is usually the clue heard prior to the L1 code.
Posted on Dec 01, 2007
SOURCE:
What of when 6L is blinking
5 02 Copy lamp lighting abnormalityH2 00 Thermistor open
H3 00 Heat roller high temperature detection
H4 00 Heat roller low temperature detection
L1 00 Scanner feed trouble
L3 00 Scanner return trouble
L4 01 Main motor lock detection
11 Shifter motor trouble
L6 10 Polygon motor lock detection
L8 01 No full wave signal
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication
Jul 15, 2014 | Sharp AR-M205 Copier
We have a Sharp AL 165 1CS Copier and an error is showing. Cannot locate our manual. Error is: [L1-00]
L1; Mirror base feed trouble.
cause:-
Mirror unit defect
Mirror home position sensor defect
Check the scanning operation with
SIM 1-1.
Dec 20, 2010 | Sharp Office Equipment & Supplies
Orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP DeskJet 932c InkJet Printer
Sharp AL 2080 Copier
There is a transparent plastic knob underneath the scanner unit that holds it in place while in its box. After installing you must turn clockwise this plastic to release the scanner mechanism. otherwise a L1 Error will appear on screen.
imaginguru
[email protected]
Oct 23, 2008 | Sharp AL-2080 Pegasus...
L 1 blinking
L1-00 is a mirror base feed trouble. Make sure the scanner mirrors move freely. Check for a scanner lock usually underneath the scanner frame to make sure the mirrors aren't "locked". otherwise check the cables and belts in the optics section but do NOT didassemble them without experience doing so. Lubricate scanner rails. Usually caused by accidental scanner lock engagement.
May 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1661CS
Your driver is either not correct or corrupted so first uninstall and then reinstall your printer driver. Your problem will be fixed up.
Feb 14, 2008 | Sharp AL-1661CS All-In-One Laser Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
