Question about Stihl Garden
Bad coil I have a 170 and it runs great until I get to 3/4 throttle then it bogs. I thought the chain may have been binding so I took off the blade and it does the same thing. Thanks
  • Stihl Master
  • 1,807 Answers
Could be an air leak. Possible split in the fuel hose, damaged carb gasket or diaphram, sucking air. Could also be muffler carbonized.
Posted on Jul 27, 2013
  • 24 Answers
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
  • 227 Answers
SOURCE: my chain keeps binding up, i get it back on, start
Try putting a new bar on it. Sometimes during use the grove in the bar gets a kink in it. This will cause the chain not to move like it should. Also, the sprocket at the end of the bar can go bad also causing a malfunction.
Best bet!!!!!! Buy a new bar...
Posted on Aug 04, 2009
dontbother10
  • 2220 Answers
SOURCE: The chain is not moving on Poulan 4018 Wild Thing
I think you are saying the centrifugal clutch does not engage. It should not at idle. Did you rev it up a little and it still not engage? There is a clutch face on sprung weights that should expand and turn the clutch drum above idle. Please see the “Handle, Chassis & Bar Assembly” detail for clutch illustrations.
A 2375 has an outboard clutch (the chain is between the engine and clutch drum).
2375 Type 7 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
Use this as a guide to remove the clutch and inspect the parts:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
A 4018 has an inboard clutch (only the drive sprocket extends into the clutch cover). Do this first then use the outboard procedure to remove the remaining clutch pieces.
PP4018 Type 2 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/PP4018-Poulan-Pro-Gas-Saw-Type-2/75.PP4018-Poulan-Pro-Gas-Saw-Type-2.1.59.1.html
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
If these are not your saw it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
You can reply below with questions or if 1 miss understood your problem. HTH
Lou
Posted on Jan 18, 2010
dontbother10
  • 2220 Answers
SOURCE: my chain saw bogs down like it is binding up
I do not recommend operating your saw at full throttle without the bar and a properly adjusted chain.
Remove clean and reinstall the air filter and muffler, do not forget the spark arrestor. If it the problem persists turn the "H" needle valve CCW 1/8 turn. Better?
This is a very good adjustment procedure.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Posted on Feb 20, 2010
  • 57 Answers
SOURCE: I have a Husqvarna 55 and it will cut but not
Is your chain sharp? Sometimes you hit stuff in wood without realizing it and it dulls your chain, dirt, nails, trash, it's all bad for the chain. If you aren't getting enough oil on your chain while cutting it will also shorten the life of your chain dramatically.
Posted on Apr 26, 2010
2006 attic cat 400 runs great in 4x4 but when you hit the switch to 2x4 runs bad like it's booging down
'03 400 backfiring/bogging under throttle - ArcticChat.com ...
www.arcticchat.com > ... > ATV's > General ATV Discussion
Apr 3, 2007 - 7 posts - ‎7 authors The engine would only sputter and bog down, kinda like the choke was hung. ... I didn't remember the fan running, so I checked the fan fuse, but it was ... of the windings and cause a misfire, so bad that it would kill the bike. '07 F8 intermittent start and bog issue - ArcticChat.com
Dec 23, 2012
Arctic cat suzuki 700 efi wont start - ArcticChat.com ...
Apr 28, 2012
400 4x4 idles but bogs out when throttle pressed ...
Jun 29, 2011
cat is slowly dying
Oct 10, 2008
More results from www.arcticchat.com
Oct 21, 2015 | ATVs
My 93 chevy 350 has issues. I'm Stumped???????????
back firing through the carby is an indication of valve timing, bad valves, ignition timing or crossed HT leads. Check the firing order
Mar 09, 2015 | Chevrolet Cars & Trucks
04 DODGE Ram hemi cylinder 3 misfire
Check engine compression and compare. then test running engine compression most engines have about 130-170 cranking compression and about 90-110 running compression. OR bring that cylinder to its Top Dead Center compression stroke apply air to the cylinder and check to see where the air is going open throttle plate bad intake valve, from exhaust pipe bad exhaust valve, from oil cap piston rings.
Mar 23, 2014 | 2004 Dodge Ram 1500
Starts fine when push throttle it bogs down have to turn choke on to keep running but runs great wide open 1989 yamaha phazer
you probley have a weak coil it has enough power to start and run at low speeds but at high speeds the coil does not put out enough spark
Dec 15, 2013 | Winter Sports
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a Husqvarna 55 and it will cut but not great. The chain will stop and the engine will bog even on full throttle. Is it the clutch?
Apr 26, 2010 | Garden
My 420 with an onan runs great at half throttle, then bogs down.
Are you sure you did not get the jets in the wrong places when you cleaned that carburetor.
Aug 23, 2009 | John Deere Garden
93 polaris xlt tripple wont run to full potential
The issue I had with my 94 was due to an oil adjustment, wich you can find below the carbs. It ran great at full throttle but once it sat at idle, the plugs would get wet and the same type of bog would accure. Get new plungs and make sure all three are firing first, if they are then the oil adjustment is off. If not sorry to say but you may have a bad coil.
Feb 10, 2009 | APW Wyott Sport & Outdoor - Others
98 chrysler concorde wont start, and when it does, it bogs down
on the throttle is a valve/sensor with a carbon track in it and i think it needs changing .not a cheap thing
Dec 30, 2008 | 1998 Chrysler Concorde
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
