Question about Home Security
Legacy garage door opener
I have a Legacy door opener that worked just fine a few hours ago. Here's the current status: - car remote does not open door - wall-mounted keypad does not open door - main, wall-mounted, wired opener with lite button does not open door - the outlet to which it is connected is juiced on both plugs - the red glow lamp that illuminates the 'light' button on the wired opener on the wall IS lit, but does not turn on the light when pressed - the LEARN button, when pressed, makes the red programming light flash as expected - the car remote, when assumed-ly reprogrammed, still does not open the door - battery in car remote is fine - I am stumped... I currently have the opener unplugged and will wait 30 minutes or so and will try again. Any thoughts? Is there some "reset" button that I don't know about? I want to try all options, of course, before I buy another opener. Thank you.
myob247
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Posted on May 17, 2009
  • 3197 Answers
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on Aug 25, 2009
  • 3197 Answers
SOURCE: 2006 Honda Accord Garage door Homelink Program with Chamberlain
useful info.
Posted on Sep 14, 2009
I have an overhead garage door Legacy 496cb/d that stopped 3/4 of the way in the down motion. It now will not open or close and only clicks. The lights work and power is on.
If this picture at the link shown looks like yours, the red and white cord with the red plastic piece needs to be pulled to disconnect the automatic door opening chain.
http://www.aypapaquerico.info/overhead-door-legacy/overhead-door-legacy-large-size-of-garage-and-modern-overhead-garage-replacement-with-legacy-opener-overhead-door-legacy-496cd-b-manual/
Then, pushing the garage door fully open should move the mechanism back to connect in the ceiling. Then the remote control may work. If not, seek a repair service.
Mar 18, 2018 | Building Materials
What is the battery size for a genie garage door remote opener model gict390
The GICT390-1 (one button remote) and the GICT390-3 (three button remote) both use a 2032 coin cell battery.
The manual for the GICT390-3 is available from Genie on their Programming Accessories page: http://www.geniecompany.com/garage-door-openers/programming_accessories.aspx . The direct link to the instructions is: http://www.geniecompany.com/data/products/accessories/manuals/legacy/36484U_1-Btn%20IC1,%20390_3577435796.pdf .
I hope this helps.
Feb 25, 2015 | Televison & Video
Subaru legacy homelink only works when car is running and doesn't work in the garage
I assume you mean the key has to be on which is true... but if you had to close the garage door when inside a running car then you would die so it is set up that way on purpose to not kill you...when you leave the garage door will close correct, and that is cuz it knows you will stay alive and that is how good technology is these days
Sep 24, 2014 | 2015 Subaru Legacy
97 OUTBACK LEGACY REAR DOOR WONT OPEN
if wont open from in or out door panel has to be removed and will be damaged most of the time. and it may take up to three hours to get door open then more time to repair take to a good shop it can be job. depending on what happened it can take a few minutes to open some times a air chisel must be used.
Aug 19, 2012 | 1996 Subaru Legacy
Looking remote chain for Legacy overhead door opener. Model #696CD/B
Legacy openers use the same remotes as Genie Intellicode 390MHZ. Should be able to get one at any lowes or home depot.
Aug 09, 2011 | General Electric GE 13-438 Overhead Garage...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Garage door is opening when the neighbor open theirs with remot
You say you "setup the remote and the main box but doesn't solve." I think you mean you programmed the unit but I'm not sure. Anyway try holding the smart/learn button in for 10 seconds and this will erase the memory. None of the remotes should work. Now when you are sure the neighbor will not be using their opener, program your remotes. This may be what you did but I'm not sure.
Aug 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
The belt which connects the motor to the door may be slipped, place it to the correct position.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
18 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
