Washing machine series 80 model 110.20802990 will not drain, lid switch is not the problem. the lid switch haas been verified to work. The machine will not drain either the wash cycle nor the rinse cycle.
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
SOURCE: replacing lid switch on Kenmore 80 series washing machine
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Not switching from rinse to drain cycle
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Select "Search by Part Number" and enter the following part numbers: The lid switch is part #3949238 and the lid strike is part #350733. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Posted on Oct 08, 2008
TheMobilian
  • 8220 Answers
SOURCE: washing machine will not rinse and empty
LID SWITCH read more HERE
Posted on Jan 22, 2009
  • 401 Answers
SOURCE: Sears Kenmore series 80 washing machine stops after wash cycle
Sounds like the lid switch.
Posted on Jan 02, 2010
Kenmore 80 series washing machine will fill up with water, then nothing happens
Kenmore Ultra Fabric Care Heavy Duty 80 Series washing machine (Model # 110.92389200; Serial # CF 1122814) went through the wash cycle completely, but rinse not the rinse cycle. Motor was going but washer not spinning. Also smelled something like burnt rubber. Could the belt have gone out? Is this something that I can fix myself?
Mar 18, 2010 | Washing Machines
Kenmore Series 80 washing machine won't drain after wash cycle. The machine just stops.
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
Kemore 80 series, washing machine will not drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Jul 08, 2009 | Washing Machines
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
