Question about Kohler Electrical Supplies
Oil pressure switch location - Kohler Electrical Supplies
  • 50 Answers
SOURCE: oil pressure switch
Lower Right Hand Side, Front Of Engine, Below the Power Steering Bracket
Posted on Aug 19, 2008
emissionwiz
  • 77186 Answers
SOURCE: oil pressure sensing switch location
The oil switch is located on the passenger side of the truck in the back of the engine. Look for the transmission dipstick, then feel for it between the transmission dipstick and the engine block. It is hidden pretty well, but a socket wrench will fit to take it off. The new part uses a 1-1/16 socket, the old part for some reason was smaller, I think 13/16 inch. Hope that helps.
Posted on Nov 06, 2008
240SXer
  • 100 Answers
SOURCE: location of oil pressure switch on a 1997 cadillac deville
Oil pressure switches a normally located by or near the oil filter on all cars. :-)
Posted on Dec 25, 2009
  • 55 Answers
SOURCE: location of oil switch 2002 chrysler 2.7 engine
should be on driver's side right above the oil filter
Posted on Jul 18, 2010
SOURCE: location of oil pressure switch.
how change oil pressure sensor in 2001 mazda mpv dx
Posted on Apr 02, 2011
I am needing to find the location of my oil pressure switch on my 2001 lexus rx300
Hi Sean,this forum will show you your oil pressure switch locati0n,Autozone has them for 12.99. Oil pressure switch sensor location ClubLexus Lexus Forum Discussion Here's the new part.Just take off connector,get wrench and remove. Duralast Oil Pressure Switch
Sep 11, 2017 | Lexus Cars & Trucks
Where is oil sending unit located?
You're vehicle has two sensors for the oil,an oil pressure sensor switch & oil pressure sensor.If oil pressure gets below 6psi,the oil pressure sensor switch will turn a dash light on to let you know the pressure is at a dangerously low amount.So if you've got a dash light on,the pressure sensor switch needs to be replaced.Its located to the right of the oil filter housing,on a 2.0 liter.Its located to the left of the oil filter housing,on the 3.0 liter.
If your oil pressure gauge is reading inaccurately,you need to replace the oil pressure sensor instead.Its located near the ac compressor.
Oct 15, 2015 | 2003 Ford Escape
Chevy 350 oil pressure sending unit
The Oil Pressure Switch is located:Under hood, center, rear engine area, driver side of distributor, mounted in block. Here's what it looks like.he oil pressure switch is mounted to the top rear of the engine.
  1. Remove the electrical connector from the switch.
  2. Remove the oil pressure switch.
  3. To install, reverse the removal procedures.
Jul 18, 2013 | Cars & Trucks
Where is the oil sending switch located on a 2003 dodge durango 4.7
Oil Pressure Sensor
On the 3.7L and 4.7L engines, the oil pressure switch is located at right front of engine just above the oil filter. On the 5.7L engine, the oil pressure switch is located at right front of engine.
hope this helps you
Jan 15, 2011 | 2003 Dodge Durango
Where is the oil pressure sending unit located on a 1999 chrrsler cirrus
There are three engines that come with this car, there are two engines 2.0 and2.4 with the oil pressure switch located on the right front of the engine block, and then if it has the 2.5 engine then the oil pressure switch is located on the leftside of the engine block above the oil filter, good luck,.
Jan 01, 2011 | 1999 Chrysler 300M
I need to know where the oli sending unit is and how to replace it?
Fig. 1: Location of the oil pressure switch-3.3L and 3.8L engines
Fig. 2: Location of the oil pressure switch-3.0L engine
Fig.: Oil pressure switch (sending unit) schematic
The low oil pressure warning lamp will illuminate when the ignition switch is turned to the ON position without the engine running. The lamp also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
REMOVAL & INSTALLATION
On the 2.4L engine, the oil pressure switch is located on the side of the engine block facing the firewall. On the 3.0L engine, the oil pressure switch is located on the oil filter adapter housing, next to the starter motor. On the 3.3L and 3.8L engines, the oil pressure switch is located next to the oil filter.
  1. Locate the oil pressure sending unit on the engine.
  2. Disconnect the negative battery cable.
  3. Disconnect the pressure switch electrical harness.
  4. Using a pressure switch socket, deep-well socket or wrench, loosen and remove the pressure switch from the engine.
To install:
  1. Install the pressure switch into the engine and tighten securely.
  2. Attach the electrical connector to the switch.
  3. Connect the negative battery cable.
  4. Start the engine, allow it to reach operating temperature and check for leaks.
  5. Check for proper oil pressure switch operation.
Hope this helps (remember to rate this answerr).
Dec 22, 2010 | 1999 Plymouth Voyager
Can not locate oil pressure switch on 1984 honda cbx750f
on left side of engine, remove cover and the oil pressure switch is located under it on left side, you will also find the neutral switch just to the right of it
May 20, 2010 | 1989 Honda CBX 750 F
Oil pressure switch location on 1999 chev cavalier
The oil pressure switch relays the oil pressure in the engine to the instrument cluster. The switch will illuminate the OIL PRESSURE light if the oil pressure drops below 2psi (13 pa). The switch is usually located on the side of the engine, under the intake manifold on the 2.2L engine and on the side of the intake camshaft housing on the 2.3L/2.4L engine.
Fig. 1: The oil pressure switch is located on the engine block under the intake manifold and is accessible from underneath the vehicle-2.2L engine
Fig. 2: Oil pressure switch location-2.3L/2.4L engine
Other, the low oil level switch activates the OIL light in the instrument cluster when the oil level in the pan goes below a certain level. The switch is mounted on the oil pan.
Hope this helped (remember rated this post).
Apr 11, 2010 | 1999 Chevrolet Cavalier
I am trying to find a picture that will show me where the Oil Pressure Switch is located
On the 2.4L engine, the oil pressure switch is located on the side of the engine block facing the firewall. On the 3.3L and 3.8L engines, the oil pressure switch is located next to the oil filter.
Good luck, and remember rated this help!!!
Fig. Location of the oil pressure switch-3.3L and 3.8L engines
Aug 11, 2009 | 2000 Plymouth Voyager
OIl PRESSURE SWITCH
The oil pressure switch is located next to the oil filter
May 20, 2008 | 1998 Buick Park Avenue
Electrical Supplies Logo
18 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
