Question about Mark Of Fitness MF-36 Digital Blood Pressure Monitor
Instruction manual How do you calibrate this unit to check authentic readings
  • 21 Answers
Http://manuals.harborfreight.com/manuals/67000-67999/67212.pdf
Posted on Jul 27, 2013
Need to know how to calibrate
What is it exactly you're trying to calibrate? typically in any form of calibration, you need a unit and method of measure, initial specifications so you know where you're calibration needs to be set before, during, and after your work. and a method of adjusting the item to be calibrated. usually a haynes manual, or other form of service manual will provide you with more detailed instructions on the specific type of car/truck/ etc you're working on. Hope this helps
May 09, 2016 | Cars & Trucks
What do I have to do to get proper depth readings on my hummingbird 561. Instead of reading 4ft it reads 08
read the user manual as to how to calibrate the unit
remember that it reads the distance from the sender unit to the sea bed/river bed and not from the display unit
May 28, 2015 | Hummingbird Boating
How do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
Jul 12, 2012 | Exercise & Fitness
I need calibration instructions
This unit is self calibrating. There is no method for manually calibrating this tool. Just hold the sensor flat against the wall and depress the button. After a few seconds the unit is calibrated and you can begin sliding it smoothly across your wall to detect studs and wires.
Dec 29, 2010 | Black & Decker BLACK DECKER BDL153S Stud ...
The screen displays a vertical group of black and grey lines. Won't shut down?
it seems like its in calibration mode
Turn unit off
Slide Power Key to the right ( lock )
Hold your finger on the screen for approx 30 seconds until calibration screen appears
Follow on screen instruction''
Here is a online Manual for your unit that I found .... http://www.retrevo.com/pdf/23127ci168/76/Calibrating+the+Screen#q=Garmin+285WT
Oct 28, 2010 | Garmin Nuvi 285WT GPS Receiver
How do i calibrate a dw 087k laser
Here is a link for the owners manual for that particular laser. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/593338-00,DW086.pdf
In there are the instructions for a Field Calibration Test. These units should be sent to DeWalt Factory Service for Calibration. If the unit is less than 1 year old they should calibrate it for free under their "1 Year Free Service" warranty.
Oct 09, 2010 | Dewalt Dw087k Selfleveling Line Laser...
Compass reading on GPS 60cSx about 30 degrees too high
Calibrate the compass (Main menu --> Setup --> Calibration --> Compass), follow the instructions on the screen.
Also, see page 50 of the manual.
Calibration must be done outside - stay clear of any large metallic object (e.g. car).
Mar 11, 2010 | Garmin GPSMAP 60CSx GPS Receiver
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
AP35 Autopilot
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Hi,i have a whistler 1773 laser-radar detector and it reads on the display DISTORT.i can't find anything in the owner's manual or on the website.can you help?thanks, angie
If compass is not calibrated correctly or if there is a strong magnetic field (dash or windshield mounted speakers), the unit will show incorrect direction or display "DISTORT". Re-calibrate the compass to correct the readings. Units that display "DISTORT" need to be moved farther away from the speakers or other magnetic field, then re-calibrate the compass. Optional Theft Protection/Extended Warranty Theft Protection
Whistler's optional 3 year theft warranty program (effective January 2002) offers the detector user protection against theft of their laser/radar detector. In the unfortunate event that your detector is stolen, it is comforting to know that your detector will be replaced! Simply follow the directions on the form enclosed with your unit or print out our online form and mail it, along with a copy of the receipt and payment, to the address listed. Once the form and payment is received we will provide you with a reference number. Note: The theft warranty protection isn't in effect until you receive a reference number from us. Our current program requires that the form and payment must be returned within 30 days of purchase, however and for a limited time only, we are waiving the 30 days from purchase requirement. If you have purchased any 1600 series laser/radar detector (This special offer is not available on any other detector model.) you are not too late, simply follow the instructions on the form and mail it in to us. In the unlikely event that your detector was stolen, simply inform us within 30 days of the theft and provide the following information:
  • Your theft protection reference number (Issued upon receipt of payment)
  • Name
  • Current complete address
  • Daytime telephone number
  • Email address (if applicable)
  • A copy of the police report indicating that your Whistler detector was stolen.
Once the above requirements are met a replacement or equivalent unit will be sent to you within 15 business days.
This offer is made available only to the original purchaser of the detector and is non transferable. Once used, this warranty is cancelled and a new one must be purchased for coverage of the replacement unit.
This offer is available in the U.S.A. only. Theft applications or claims from outside the U.S.A. will not be accepted and a copy of the original store receipt MUST accompany this form!
Extended Warranty
We are pleased to offer you an extended warranty for your Whistler laser/radar detector. Under the extended warranty, your detector will be warranted to the original purchaser for a period of 1 year from the date of expiration of the original warranty against all defects in materials and workmanship. To purchase the extended warranty, simply follow the directions on the form enclosed with your unit or print out our online form and mail it to the appropriate address provided, along with a copy of your sales receipt and a money order for $20.00, or payment can be made by Visa, MasterCard, American Express. (No personal checks will be accepted). You must receive a reference number (issued upon receipt of payment) from Whistler in order for your warranty to be in effect. This limited warranty is void if the unit is abused, modified, installed improperly, if the housing has been removed, or if the serial # is missing. There are no express warranties covering this product other than those set forth in this warranty. Whistler is not liable for damages arising from the use, misuse, or operation of this product. When returning a unit for service under warranty, please follow these instructions: Ship the unit in the original carton or in a suitable sturdy equivalent, fully insured, with return receipt requested, and shipping charges prepaid to:
The Whistler Group
Customer Repair Center
1201 N Dixieland Rd
Rogers, AR 72756
Include with your unit the following information, clearly printed:
  • Your name, street address, daytime telephone number and (if applicable) an email address.
  • A detailed description of the problem.
  • A copy of the sales receipt and extended warranty reference number.
To validate that your unit is within the warranty period, make sure you keep a copy of the original store receipt and the extended warranty reference number issued by Whistler. IMPORTANT: Whistler will not assume responsibility for loss or damage incurred in shipping. Therefore, please ship your unit insured with return receipt requested. -->
Feb 18, 2008 | Computers & Internet
Mark Of Fitness MF-36 Digital Blood Pressure Monitor Logo
386 people viewed this question
Top Mark Of Fitness Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Mark Of Fitness Health and Beauty Expert? Answer questions, earn points and help others
