Question about Golf
Golf cart repair
I have a 2000 gas club car kawasaki engine runs for for about a mile or 2 then wont start it turns over and if i let it sit for a bit it starts up again runs rough back fires and sputters i change fuel pump spark plug air filter fuel vacuum line gas line clean the carb still having problems ?? whats next
  • 255 Answers
SOURCE: my tracker wont start up
Hi. you should replace air filter and ad a gooooood fuel ingection cleaner ,this should help.Good Luck
Posted on Aug 17, 2008
skotkolr
  • 558 Answers
SOURCE: 2000 toyota tacoma 2.4l wont start when cold
clogged injectors you need to put cleaner in the fuel to help get dirt and grit out of them some times (every 3 months).
I am assuming you are saying it will turn over but not fire and run when cold?
Posted on Mar 21, 2009
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
SOURCE: Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
Posted on Jun 08, 2010
1987 owners manuel for a club car golf cart
Club Car Manual Club Car Serial Number Club Car
1984 2008 Club Car Golf Cart Repair Manual Download
Sorry, I can't find a free 1987 version. The first link is a way to directly order from Club Car. No way for me to know for sure but you might take a look for similarities in the following: http://www.clubcar.com/content/dam/cc-corp/documents/pdf/pdf/ownersmanuals/DS-Manuals/1014409%201287B00000.pdf
Aug 10, 2017 | Golf
Yamaha golf cart 1996 ulima g14ap engine jn3 200191 start but wont stay running put a new fuel pump on still wont stay running y
Have you cleaned the carb? Many times if they sit up with this ethenal gas it eats the seats an causes a gell to form in the carb bowl. I would check an clean carb first with new gas.
Jun 01, 2017 | Golf
I have club car golf cart. I get to start,later it won't start,looks like no gas is coming in to carb
if is is fuel problem check the fuel filter and or carb needs to be repaired or replaced possible debris or float valve sticking
Sep 13, 2016 | Golf
We have a 1999 gas club car golf cart just replaced the ignition coil. It now won't turn off
You need to run a wire to the coil from the hot wire coming from your key/ignition switch. This will ground the coil and eliminate the spark.
Sep 02, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
My club car gas golf cart was running good then al the sudden wont go over idle speed
Perhaps it's a stuck carburetor float valve, bad fuel pump (if it has one) or clogged fuel filter.
Jul 03, 2015 | Cars & Trucks
Club car gas will run but will not pull
Check the drive belt. goes between the centrifugal clutch mounted to the engine. Usually 2 shinny "V" shaped cones that look line this ><. The belt goes between the cones (where the "x" is: >x<). The belt may have broken or slipped off or needs to be replaced or adjusted.
Jun 17, 2014 | Dual Club Car Lester Power Drive Charger...
Need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Sep 30, 2008 | Computers & Internet
Golf Logo
32 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
