Question about Whirlpool Refrigerators
Control panel not lighting up, refridgerator has power
Model no gc3phexns02
    New Friend:
  • 41 Answers
Check your fuse.
Posted on Jul 29, 2013
Refridgerator beeps
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 19, 2015 | Refrigerators
Lights on gas for 1 minit an gos out chek light comes on
I had this problem on my Dometic Refrigerator. I am not sure of the model however after checking the gas and making sure the the gas heater was lighting my problem was fixed by replacing the control board which is in the back of the refridgerator. This contrl board will sense that the gas burner is lighting and heating otherwise it will set the check light on the front panel and turn off the gas. I was able to find a source for the control panel at not to high of price on ebay. The new panel was redesigned and will not overheat. Which was a problem on the older models. My refrigerator was manufactured before 1995.
Jun 19, 2014 | Dometic RM2652 Refrigerator
GE profile fridge mod# PDS20SCRRSS is not cooling at all. Lights are on but no other units are powered. Pulled cover off board and fuse looks good. Smells burnt. Am I on right track?
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair.
May 08, 2012 | GE Refrigerators
Stopped working
I had the problem with a totally different refrigerator but it was the fuse on the printed circuit panel mounted in the back of the refrig.
Nov 20, 2011 | LG LSC27910 (265 cu ft) Side by Side...
Refridgerator & freezer not cooling much, ice crystals on inside of freezer
Need you to unplug and remove the back panel in freezer to examine the evaporator coil. Check the defrost element and the defrost thermostat. On the back of the refrigerator is a main control board located behind a panel screwed to the refrigerator back. With the power off through all of this I need you to inspect the control board for burn marks on both sides. Click on link below and enter your model or 1 of 34 models like yours. Place model GSH25JFR in model parts search this will lead you to the many similar models like yours. On diagrams on left of your screen count eight down that shows the circuit board. If no burn marks I will tell you how to test the other parts I mentioned,
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Refridge compartment warm not cooling
I hope the following helps.
Turn the entire control system off for at least two minutes. This will give the computer module time to reset to factory default. Turn of to desired level after two minutes. Should that not work then there is a problem with the timing relay. They relay is brand specific, meaning take the model number to the parts store for a new one.
Your compressor should be fine. You may also remove the power by unplugging the refrig.
CAUTION: Before removing the relay the power to the fridge must be OFF. Failure to have it in the off postion can cause the new relay to short which can lead to mkore problems. So UNPLUG the fridge, remove the relay, replace the relay and then plug fridge back min. Set control to desired cooling level and wait a couple hours. That should do the trick.. IF not then there is an issue with the processor module.
Jan 04, 2009 | Refrigerators
Whirlpool Refridgerator Problem
you didnt include the model, but i would assume that the "control panel lights " are also out??, and a clicking noise when the refrig door is opened??? if so you have a bad electronic control board. its located behind the refrig on the left hand side munted inside a little white box next to the compressor,
Oct 26, 2008 | Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
