Question about RCA Thomson Digital Cable Modem (DCM305R)
My thomson tg585v8 not conected to bsnl line please help me
I have just purchased a Thomson tg585v8 and am unable to log into the Thomson Gateway. I have tried all the usual defaults like; admin, admin; Administrator, Cp********, Administrator, "blank" etc. I have...
you do need to hold the button for awhile sometimes
Username: admin
Password: The serial number on the bottom of your router router. It begins with the letters CP.
this should get you in!!
Nov 17, 2013 | Computers & Internet
My comp.says network error,thomson tg585v8,i cant access my comp.
Check your network settings
Start, control panel, networking and sharing center. Click on your connection, properties. Click on TCP/IPv4 and TCP/IPv6 and click on properties. Make sure the settings say to obtain IP address automatically and also for DNS, then reboot the modem and computer.
You did not specify if you are using a router.
Jan 29, 2013 | RCA Thomson Digital Cable Modem (DCM305R)
Thompson tg585v8 password for wireless
Only you have the password, Use this procedure to reset the Device, you may want to write down the Security Key(password) for future use. : http://telecom.custhelp.com/app/answers/detail/a_id/5281/~/reset-your-modem-to-factory-settings---thomson-tg585
Jan 09, 2013 | Computers & Internet
How can i get nat type open i always have nat type strict. my Router is a thomson tg585v8
I believe certain routers are certain NAT types. If there is not an option to change NAT type on the web interface for your router, then it is what it is.
Hope that helps
Christopher
May 15, 2012 | Zyxel P660HW-D1 Router
I have no problem in the conections to the net, but i have used all the possible user names and passwords but i still can not inter thomson gateway . i use tg585v8-router
Reset the router and start the configuration from the begining. There's no need to "crack" the password or user name if you physically have the device.
Make sure you write down and save the password after you change it from its default or you will have to do this over again.
Sep 12, 2011 | Computers & Internet
I want to change the wa mac address on my Thomson tg585v8 router
You can't change a MAC address. It is a burnt in address put in by the manufacturer of the router. There are ways to spoof an address or use the MAC address of your PC when accessing the Internet. You can change your IP address if that is what you are trying to do.thomson.jpg
May 20, 2011 | Computers & Internet
I have just purchased a Thomson tg585v8 and am unable to log into the Thomson Gateway. I have tried all the usual defaults like; admin, admin; Administrator, Cp********, Administrator, "blank"...
Hello, usually the default for this type of router is;
the default username is Administrator (case sensitive). the default password is blank.
Be sure to type the user name with an capital 'A'
:) Hope this helps!
Feb 28, 2011 | Computers & Internet
We can not set up thomson tg585v8
I am having problem to enter into the router configuration
Dec 12, 2010 | Computers & Internet
I need BSNL GPRS setting for my PC via bluetooth. Please help.
pc suite se conect karo phone ko phir conect to internet ko klik karo uskbad mumul setting me jakar one touch access me minuali access point type karo jo aap ko castumber care se miljaye ga
Dec 04, 2010 | Cell Phones
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
RCA Thomson Digital Cable Modem (DCM305R) Logo
74 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
george  peters
george peters
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
