Question about Garden
B&S 31D777 TORQUE
HEY EVERY ONE HELP I NEED THE TORQUE ON A 31D777 ENGINE I AM REBUILDING I NEED THE ROD AND HEAD TORQUE PLEASE HELP THANK YOU DOUG
StormStrikes
  • 104 Answers
SOURCE: TORQUE SETTINGS ISUZU RODEO FOUR CYLINDER
I dont know the specific answer for your question, but I own a 1995 Rodeo and there is an online community you could probably check out that Im sure would have the answer for you.
Check out www.planetisuzoo.com, sign up and post your question there. There are several knowledgeable people there and some good information as well.
Posted on Jan 03, 2009
SOURCE: torque specks
hi 1999 chevy malibu head bolts 1-8 40 ft lbs bolts9-10 30 ft lbs tighten all bolts an additional 90 degrees
rod bearings 18 ft lbs plus additional 80 degrees
head
top row of bolts 9 3 1 5 7 bottom row 10 6 2 4 8 from left to right
Posted on Feb 12, 2009
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
robotek
  • 1512 Answers
SOURCE: Rebuilding a Honda 2004 CBR 1000 RR Engine I just
Hi Paul,
You can download a copy of the entire manual, torque setting, head stud pattern, and every other usefulbit of info from here. Godd luck with the rebuild, let me know if you have any dramas with the manual. Cheers.
regards robotek
Posted on Apr 08, 2009
SOURCE: need torque specs for a 85 s10 chevy with a 2.5 engine?
here you go!
Posted on Jun 21, 2009
2005 TOYOTA HILUX KUN25R DIESEL ENGINE TORQUE SPECIFICATIONS
Hey
As i know you face a lot of problem.Due to this I give you one mail address it really help full for you.Please visit it.
May 03, 2016 | Toyota Cars & Trucks
2005 corolla head bolt torque
A Chiltons/Haynes repair manual from your local auto parts store that covers your year/make/model has all of your answers under the "engine rebuild" heading.
Sep 23, 2014 | 2005 Toyota Corolla
Torque specification
petrol engine alloy head 65lbs
main bearing caps 80lbs
big end bolts 40lbs
Nov 21, 2013 | Cars & Trucks
Cylinder head bolt torque setting
The confusion may have come from a number of possible sources.
For the 2.5 Liter engine, the bolt tension is 80 Foot pounds or 108 Newton meters. cold engine only. No retorque and No retorque when hot.
This is from the Auto Engine Rebuilders Association literature.
Jan 07, 2012 | Cars & Trucks
Hi we are rebuilding a ford 4600. Can anyone tell me the torque settings for the bigend, main and head bolts please? Any help would be great, Thanks bb
On the head, first tighten the bolts following the sequence to 40-50 ft-lbs, run through the sequence again and tighten to 70-80 ft-lbs, and again at 95-105 ft-lbs. The intake valve clearance to .017; exhaust is .021. Connecting rods torque 60-65 ft-lbs. Main caps torque to 115-125 ft-lbs.
Randy - TMS Stoller Tractor
Jul 05, 2011 | Ford Tractor Grill 2600 3600 4600 5600...
4bc1 engine torque settings, al settings requirred please in ft/lbs , ie , cylinder head , main bearings , con rods , valve clearances , etc
This is a really long list and will be difficult to satisfy, but there is help. You can go to your local parts store and purchase a Haynes manual, it contains all the specifications and steps for rebuilding a vehicle of your choice, they are accurate and helpful. with a lot of illustrations and written out steps for any and all procedures.
Jun 08, 2011 | 1983 Isuzu Pickup
I need torque specifications for a 93 Saab 9000 engine: Head bolts and also for the connecting rods Thank You JLM
YOU NEED TO MAKE 3 PASS FIRST PAST TORQUE CYLINDER BOLTS 44 FT LBS. SECOND PASS TORQUE CYLINDER BOLTS 59 FT LBS. IF YOU HAVE 17MM HEAD BOLTS TORQUE TO 70 FT LBS.THE THIRD PASS TIGHTEN ALL CYLINDER BOLTS ADDITIONAL 90 DEGREES. ROD BEARING BOLT TORQUE TO 35 FT LBS.
May 10, 2011 | Saab 9000 Cars & Trucks
1994 buick lesabre limited connecting rods torque and head torque
Hello insebard: My name is Roger and I will help. The connecting rods torque to 20 lb.ft. plus50 degrees. The rods torque in 3 steps they are. Step one. 35 lb.ft. Step two tighten an additional 130 degrees. Step three. tighten the 4 center bolts an additional 30 degrees. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Rogerb9c720e.jpg
Mar 24, 2010 | 1994 Buick LeSabre
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
