Question about Maytag Neptune MDG5500AW Gas Dryer
Noises I have a Maytag lde9316ace dryer that makes a loud grinding noise just after starting and stopping. While running, there are rattling and rumbling sounds. I removed the front cover and bulkhead. Then held the drum in place and rotated it; it turned smoothly and the blower fan turned OK too. If I manually turn the drum on the fully assembled dryer, I hears noises and it doesn't seem to turn smoothly. Could it be simply that the glides on the bulkhead need replaced, or is there more going on here. The machine is 15 years old, so is it worth repairing, given the possibility that more stuff can go wrong?
  • Russ Jul 27, 2013
    The grinding noise is made by something "catching" the drum. I justs noticed that when I open the door while it's running, the drum spin freely for a couple seconds, them stops suddenly with the grinding noise.
  • Russ Aug 19, 2013
    It was the blower wheel. A shop in my town had it in stock for $20.00. Problem solved. Thanks for the consideration.
    Top Expert:
  • Maytag Master
  • 50,572 Answers
After 15 years of service I imagine it will be hard to get the parts you want to repair it.. Newer machines may not dry as quickly as the older types but they use less power to do so.. Consider a new machine for the sake of the economics of the problem
Posted on Jul 29, 2013
4 Suggested Answers
dtci80
  • 125 Answers
SOURCE: My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Posted on Oct 21, 2009
  • 11 Answers
SOURCE: maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Posted on Jan 18, 2010
kevster6720
  • 171 Answers
SOURCE: Our two year old Maytag
this is most likely a broken wheel which is a wheel that the bearings have worn out on.If it is a wheel you should replace the set because if you replace just the one the others will wear out faster than they should.
Ps if it is only two years old it may still be under warranty!
Posted on Oct 07, 2010
Loud grinding noise
These are the bearing that the drum rides on. There are bearings in the back and the front. Replace all of them where you hear the grinding, front or back.
Jan 08, 2014 | Maytag Neptune MDE5500AY Electric Dryer
6000 Series Rattle & Vibration
Sounds like the drum wheel or wheels need replaced .The twist frame thing just doesnt line up sorry ..LOL
Aug 19, 2013 | Maytag Dryers
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
My dryer has started to make a loud rattling noise when drying. It works fine but the rattling noise is coming from the lower back part of the unit and nothing seems to be loose. What can I do?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 18, 2011 | Maytag Dryers
The dryer is making loud noise
heatman101
er789
Jun 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
A loud rattling noise occurs when the dryer is running
heatman101
fjd
Dec 13, 2009 | Maytag Neptune MDG6800 Gas Dryer
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Maytag MDG7600AW Gas Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
105 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
