Question about Venta Airwasher VS 207 3.7 Gallon Humidifier
Why is it clicking?
I had it for a few months now and about an hour after turning it on it makes a clicking noise.
NOISY FAN ON HUMIDIFIER HUNTER 34356
Try using WD-40 or sewing machine oil on the bit that the blades are independent from the motor usually just a small opening that you can try to spray some lubricant in there which will reduce friction and noise by lubing up the bearing and decreasing wear if that helps you will then know what the underlying issues are and if you need further action
Sep 24, 2017 | Hunter Humidifiers
After a few hours my Aprilaire 400 makes a constant clicking sound that won't stop. Is it the solenoid?
This is either the solenoid or a loose low voltage wire. Make sure all the wiring connections are tight, if they are the solenoid if bad and will need to be replaced.
Dec 14, 2012 | Aprilaire 400 Humidifier
Aprilaire Humid. Model 560 - not working even though water is on
Make sure the heat is running during test.Does the pump make noise.The control shoud make a soft click when u turn the knob on/off.
Mar 07, 2010 | Humidifiers
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Valve makes a loud clicking noise and activates over and over again
Sounds like your humidistat is the problem. Try turning it off, if still clicking, disconnect one of the wires at the valve (if accessable). If the valve doesn't close, replace valve. Otherwise replace humidistrat.
Nov 27, 2009 | Honeywell Humidifiers
MOTOR IS NOISE
Sounds like your motor bearings are going bad. If at all possible lubricate the motor bearings using a few drops of a NON detergent oil. If the motor has sealed bearings with no oil ports then you should replace the blower motor.
Good luck
Mar 29, 2009 | Essick Air 447 302 Console Whole House...
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Venta LW44 - KNocking sound and only 1 of the 2 wheels turn
This sound is could mean that the life of the gear has been used up.
This is a common problem. It is easily fixed for $10 + Shipping. The gear needs to be replaced. Try this link to have someone call you. abdistrsupport@gmail.com
Remove the gear and turn on the unit to see if the noise still exists.
  • If noise stops, the gear and coupling needs to be replaced
Dec 10, 2007 | Humidifiers
Aprilaire 600 humidifier solonoid valve chattering in sync with d10 led
I fixed my problem by ordering a new control unit (model 56) from IAQSOURCE. Installing the control unit took a few mintues, and once the new control module was installed, I've had no more problems. The URL is as follows: http://www.iaqsource.com
Oct 12, 2007 | Aprilaire 600 Humidifier
Venta Airwasher VS 207 3.7 Gallon Humidifier Logo
50 people viewed this question
Top Venta Humidifiers Experts
Paul Carew
Dennis
Are you a Venta Humidifier Expert? Answer questions, earn points and help others
