Question about Indesit W 123 Front Load Washer
Indesit wg 1285w
Our machine has stopped rotating, my husband has changed the bushes but the problem has not been resolved. The machine goes on fills up but the drum does not rotate. Power is going to both bushes at 240 volts. Help please!? dubstar
  • 67 Answers
There is no capacitor on a brush motor, more likely your motor is faulty, or you control module
Posted on Aug 31, 2007
  • 641 Answers
Replacing the capacitor might solve your problem. Good luck!
Posted on Aug 30, 2007
Washer fills water, drum is stuck
you may have a sock stuck in between the drums
rotate the drum when it becomes stiff you stop then take out the lower paddle by pulling it
you may now see the sock
Dec 01, 2013 | Indesit W 123 Front Load Washer
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
My Indesit washing maching WG 1234 T, just keeps filling up and will not start its wash cycle.
Usually, when water fills up to a desired level, for example: choosing a small, medium, or large load. The floating switch will trigger a signal to turn on the motor to turn to start the agitation. In this case, the floating switch is bad or the floating mechanism is not working. Therefore the machine didn't do anything. It needs to access to inside the back panel to check it out. Cheers.
Aug 13, 2010 | Indesit Washing Machines
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Indesit WG 635 P
model no req and product no.
Oct 05, 2008 | Indesit W 123 Front Load Washer
Indesit wd12s washer dryer
after all you have checked out I think it must be a programmer fault. Sorry I dont know how to check it out for sure
Oct 24, 2007 | Washing Machines
Control switch turns 360 degrees
your module has blown and im afraid this fault is not worth fixing due to the price of the board you may b able 2 get a second hand 1 but make sure it is a good 1 with a small g/tee rough price £50 good luck the module is mounted at the back of the machine at the bottom on the left hand side 2 screws hold it in place
Aug 17, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
226 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
