Question about Epson Perfection V700 PHOTO Flatbed Scanner
Cover Cable My cover cable has a broken pin. I need to replace it. Were can I get a replacement cable? I contacted Epson but they dont have a part number for it...
  • Charles Nix
    Charles Nix May 29, 2016
    I have the same problem almost. I need to replace the "cover cable." In my research I found a breakdown. I'm sorry I don't have the url but perhaps you could search for "Perfection V750 V700 Exploded diagram.pdf (Secured)." It listed the part as number 123. I don't know if that will hold up on other sites. Like you I am still looking. Good luck.
3 Suggested Answers
sherlyn c
  • 134 Answers
SOURCE: By using the epson v500 photo I get the following
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
Posted on May 03, 2009
ginko
  • 19396 Answers
SOURCE: I have not used the
Hi.
Yes, when you choose start Scan in the software, the light will come on and move across the document to perform the scan job.
You will probably need to install again the scanner software and driver. Please click here and download the software. With windows you need to download TWAIN DRIVER AND EPSON SCAN UTILITY.
Once download is complete, install the software running the downloaded file. You may need to restart the computer after installing. Ensure that you authorize any system change if required by Windows or by security software.
Posted on Feb 03, 2011
I ned to unlock the bios psword for dell latitude e6420
The solution depends on whether your laptop was made before or after 2004. If it is a post-2004 model, you must call Dell Support to reset the password for you.
If it is a pre-2004 model, you can follow these steps:
Perform the safety steps in the order below.
Warning: these steps are for your personal safety and the protection of the equipment.
    Turn off your computer, and then unplug the power cable.
  1. Wait 5 seconds.
  2. Disconnect all external devices.
  3. Disconnect any telephone or network cables from your computer.
  4. Press and hold the Power button while your computer is unplugged to dissipate static electricity from the motherboard.
  5. Before touching anything inside your computer, ground yourself with a wrist-grounding strap or by touching an unpainted metal surface, such as the metal at the back of your computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
To use the jumper to reset the BIOS password
Note: On the Dell Manuals page, download the Setup Guide or Service Manual for your laptop. Then refer to the System Board Components section for a labeled illustration of the jumpers on the motherboard.
  1. Ensure that your work surface is flat and clean to prevent scratching your laptop's cover.
  2. Remove the battery from your laptop.
  3. With your laptop still turned off and unplugged, remove the cover.
  4. To locate the password jumper on the motherboard, look for the letters PWD, PSWD or PSWDCLR.
  5. Choose an option:
    If there are 2 metals pins under the jumper
    1. Remove the jumper from the pins, replace the cover, reconnect the power cable and turn on your laptop.
    2. After the Windows logon screen appears, turn off your laptop.
    3. Again, disconnect the power cable. Press and hold the power button for 10 seconds to release static electricity from the system.
    4. Remove the cover.
    5. Replace the jumper in its original position covering the 2 pins. This will re-enable password feature.
    6. Replace the cover.
    7. Reconnect the power cable and other connections, replace the battery and turn on your laptop.
    If there are 3 pins under the jumper
    1. Remembering which two pins are covered, remove the jumper from those pins.
    2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
    3. Replace the cover and reconnect the power cable.
    4. Turn on your laptop and wait 5 seconds. Then press and hold the Power button until it turns off again.
    5. Disconnect the power cable again. Press and hold the power button for 10 seconds to release static electricity from the system.
    6. Replace the jumper over the original 2 pins.
    7. Replace the cover.
    8. Reconnect the power cable and other connections, replace the battery and turn on your laptop.
    You can now assign a new system and/or setup password. For more password information, refer to the Passwords section of your laptop's service manual.
Nov 23, 2013 | Dell Latitude E6420 PC Notebook
How do I replace my clutch cable on a 98 dyna low rider
You will have to replace the entire cable. Also buy a transmission side cover gasket because you have to take the cover off to replace the cable.
Aug 12, 2012 | Harley Davidson FXDL Dyna Low Rider...
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
When i close the cover the "cover open" is still
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover.
Nov 16, 2010 | Lexmark X3480 All-In-One Printer
My elitegroup laptop was no power at all, then the pin positive is shorted to pin negative
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | EliteGroup G320 Notebook
Not working dont get power in motherbord
Sep 23, 2010 | Acer ASPIRE 3680-2022 Notebook
Fuel flap wont open
YOU MAY BE ABLE TO TIE THE NEW ONE TO THE OLD ONE AND PULL IT THRU. DONT BE SURPRISED IF YOU FIND A BACKUP EMERGENCY CABLE IN YOUR TRUNK IN CASE YOUR MAIN CABLE BREAKS. ITS TYPICALLY UNDER THE CARPET.
Mar 16, 2009 | 1996 Toyota Camry
Saab 9-3 convertable antenna will not go up. there is a clickng sound when the engine is turned off and on at the antenna.
antenna mast is no good.. you can buy a mast and have it installed or buy a used antenna and have it installed im sure Elite foreign auto parts has only saab parts.. tested and used,
Feb 17, 2009 | 2003 Saab 9-3
I need to replace the cord. There is a short near the housing.
hi may i suggest ? if you wish to renew the complete cord/wire? why not fit a longer length to facilitate more reach thro different rooms from the preferred wall socket ? the problem of short /breakage of wires within outer sleeve near casing is common on lots of vacs it is not a difficult job to replace if you are competant with wire and colour codes remove the access cover where wire enters vac then observe the attachment of each wire ? then disconnect faulty cable transfer the rubber tube that is normally fitted at entry point to vac at this point to new cable remove outer sleeve of new cable same length as old cable to reveal the inner wires then connect to vac sockets resecure cable to vac as previous dont forget the rubber tube? refit entry cover and fit a new 3 pin plug bs kite marked ? then away to vac the rooms? hope this helps
Oct 20, 2008 | Hoover Vacuums
Epson Perfection V700 PHOTO Flatbed Scanner Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
