Question about Dometic RGE400 Top Freezer Refrigerator
Works fine on electric but unpredictable on propane
New fridge with intake and exhaust hoses. May work well for 12 hours and simply shut off, or 45 mins and shut off. Very unpredictable on propane. Could wind backdraft through the hose and cause this problem? Other suggestions?
    Top Expert:
  • Dometic Master
  • 7,915 Answers
Check LP pressure regulator and gas supply make sure LP lines are clean not clogged with cobwebs
Posted on May 30, 2016
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 20 Answers
SOURCE: Dometic RM2652 will not run on electricity only Propane
Most likely your heating element burned out or else the circuit board is bad. To test the heating element unplug it from the circuit board (j6 and j7 usually gold colored) take the two heating element wires and using an ohm meter make sure there is no resistance between them, if there is resistance the heating element is bad, Or can just put a plug onto the heating element and plug it into a 110 wall outlet and see if it gets hot. If it is not the heating element it is most likely the main circuit board. (between 1993-1996 dometic used a yellow epoxy filled circuit board that went out pretty quickly) if you have the yellow filled circuit board rather than the green one it is most likly the circuit board
Posted on Feb 20, 2009
  • 9 Answers
SOURCE: Dometic refridgerator won't stay lit on Propane
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Posted on Jul 26, 2009
SOURCE: rv refrigerator will not run on electric even
motorhome fridge will not switch from propane to electric even when on auto
Posted on Apr 28, 2010
motor1258
  • 6674 Answers
SOURCE: 3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Posted on Jun 22, 2010
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
Norcold fridge berps and display says No flame
check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
Mar 25, 2013 | Thetford Norcold DE0051 Refrigerator
Cylinderhead torque stc.
Cylinder Head Removal & Installation SOHC To Remove:
  1. Relieve fuel system pressure.
  3. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  4. Loosen lock bolt on tensioner.
  5. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt.
  6. Remove timing belt from camshaft pulley.
  7. Disconnect battery negative cable.
  8. Remove 3 bolts that secure accelerator cable and air intake hose to cylinder head cover.
  9. Detach accelerator cable and place off to side.
  10. Remove the following;
    • Air hose
    • Air ISC air hose
    • Breather hose
    • Vacuum hose from air intake hose
  11. Disconnect mass air flow sensor electrical connector.
  12. Remove air intake hose.
  13. Remove PCV valve from cylinder head cover.
  14. Remove ISC air hose from idle speed actuator.
  15. Remove air hose from behind intake manifold.
  16. Remove 2 screws from high tension wire protectors.
  17. Detach wire loom from holder at rear of cylinder head cover.
  18. Detach vacuum tube at rear of cylinder head cover.
  20. Remove 7 cylinder head cover bolts.
  21. Remove cylinder head cover and gasket.
  22. Disconnect 2 ignition coil electrical connectors.
  23. Disconnect 2 fuel injection electrical connectors at rear of cylinder head.
  24. Disconnect the following electrical connectors;
    • Oxygen sensor
    • Throttle position sensor
    • Idle speed actuator
    • Oil pressure switch
    • EGR vacuum solenoid valve at intake manifold
  25. Disconnect heater hose from elbow.
  26. Disconnect brake booster vacuum hose and cruise control vacuum hose from surge tank.
  27. Detach wire harness from rear of cylinder head.
  28. Disconnect purge control solenoid vacuum hose from intake manifold.
  29. Disconnect fuel hose from fuel connector assembly.
  30. Remove grounding bracket.
  31. Remove 4 bolts and intake manifold bracket.
  32. Remove starter.
  33. Detach water bypass hose from bypass pipe.
  34. Disconnect water hoses from oil cooler.
  35. Disconnect fuel hose from fuel pipe.
  36. Remove exhaust manifold heat shield.
  37. Remove exhaust flange nuts and front exhaust bracket bolt.
  38. Lower exhaust system. Cylinder head bolt loosening sequence kia-03-20-7050.gif
  39. Loosen cylinder head bolts in 3 steps in proper sequence.
  40. Remove cylinder head bolts and washers.
  41. Remove cylinder head, intake manifold and exhaust manifold as an assembly.
To Install:
  1. Install NEW cylinder head gasket.
  2. Install cylinder head, intake manifold and exhaust manifold as an assembly.
  3. Tighten cylinder head bolts in 3 steps in reverse sequence that was used during removal. Tighten bolts to 62 ft lb (84 Nm).
  4. Install front exhaust bracket bolt. Tighten bolt to 20 ft lb (27 Nm).
  5. Install NEW lower exhaust flange gasket and 3 nuts. Tighten nuts to 24 ft lb (31 Nm).
  6. Install exhaust manifold heat shield. Tighten nuts to 35 in lb (4 Nm).
  7. Connect fuel hose to pipe.
  8. Connect 2 hoses to oil cooler.
  9. Attach water bypass hose to bypass pipe.
  10. Install starter and bolts. Tighten bolts to 34 ft lb (46 Nm).
  11. Install intake manifolds bracket and 4 bolts. Tighten bolts to 32 ft lb (45 Nm).
  12. Install grounding bracket.
  13. Connect fuel hose to fuel connector assembly.
  14. Connect the following electrical connectors;
    • Oxygen sensor
  15. Connect purge control solenoid vacuum hose to intake manifold.
  16. Attach wire harness from rear of cylinder head.
  17. Connect brake booster vacuum hose and cruise control vacuum hose to surge tank.
  18. Connect heater hose to elbow.
  19. Connect 2 fuel injection electrical connectors at rear of cylinder head.
  20. Connect 2 ignition coil electrical connectors.
  21. Install cylinder head cover.
  22. Install 7 cylinder head cover bolts. Tighten bolts to 60 in lb (7 Nm).
  23. Install vacuum pipe and 2 bolts at rear of cylinder head cover. Tighten bolts to 60 in lb (7 Nm).
  24. Connect vacuum tube to pipe.
  25. Connect loom holder to rear of cylinder head cover.
  26. Install 2 screws to high tension wire protectors.
  27. Install air hose to behind intake manifold.
  28. Install ISC air hose to idle speed actuator.
  29. Install PCV valve to cylinder head cover.
  30. Install air intake hose.
  31. Connect mass air flow sensor electrical connector.
  32. Install the following;
    • Air hose
    • Air ISC air hose
    • Breather hose
  33. Attach accelerator cable.
  34. Install 3 bolts that secure accelerator cable and air intake hose to cylinder head cover. Timing belt pulley timing marks kia-03-20-7035.gif
    NOTE: Timing belt pulley timing mark and timing mark must be aligned.
    NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  35. Install timing belt.
  36. Install timing belt cover.
  37. Pressurize fuel system.
  38. Start engine and check ignition timing.
Jul 11, 2010 | 1999 Kia Sportage
Jun 18, 2010 | Dometic RM2652 Refrigerator
Not working on propane
Shut it off, (propane) and used compressed air to try and blow up that stack and clean out any rust that may be in there, as well as check for baffle hooked at top of stack, and hangs down inside the tube.
Jun 01, 2010 | Dometic RM2193 Compact Refrigerator With...
Kenmore gas dryer works but no heat, model# 110.20702990.
make sure the exhaust vent is not plugged. shut gas off, disconnect hose, start dryer. stop and reconnect hose turn gas back on and try again.
also a propane dryer can work on on natural gas but it is very dangerous to run a natural gas dryer on propane because the orfice is too big.
Sep 23, 2009 | Dryers
Jul 26, 2009 | Dometic RM2652 Refrigerator
Will not stay lit
The pilot sequence is designed to run for 45 seconds. It could be that the thermocouple is not triggering the cycle once the pilot is lit. I am having the same problem and intend to replace the thermocouple and then give it another go. The fridge works fine on electric but stopped working on gas last week.
Jun 29, 2009 | Dometic RM2852 Refrigerator
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Refrigerators Logo
47 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
