TOSHIBA Satellite L30-10X Keyboard Set-up
I just bought a TOSHIBA Satellite L30-10X. And have 2 problems. 1. The keyboard is acting strange and I assume its got something to do to with regional settings. The '@' button appears next to the enter button, but if you press it, it shows another caracter. It does come up if you press SHIFT 2, like my HP laptop. Any help? 2. I have a USB 3G modem. It works fine if I plug it into the USB port at the back of the laptop, but not in the port at the side. It picks up the software, but will not connect to the 3G network from this port. Any help? Thanks Hardus
    New Friend:
    Problem Solver:
  • 5 Answers
Its just the problem with your USB drivers. Just update your drivers. You'll be fine
Posted on Apr 27, 2017
SOURCE:
ma_foes
  • 49 Answers
SOURCE: Toshiba Satellite L10 that will not acknowledge a usb mouse or keyboard
use a different mouse or keyboard just to be sure. if it still doesnt work refer to the documentation
Posted on Dec 14, 2007
SOURCE: Toshiba Satellite Latop - Keyboard problem when entering password
my email add is [email protected]
i need to driver for my laptop model no.is
A60 satellite
can you suggest on my email add.
Posted on Apr 03, 2008
SOURCE: 3G USB Modem internet not working on PS3
erm...cant you just plug in your 3 usb to your pc and connect to your ps3 via the ethernet cable? that should work...but i think the main issue is that it might be too slow to play online...either that or you play online for ten mins and then your done for the month lol
Posted on Mar 14, 2009
SOURCE: I can't install modem drivers
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts Vista Drivers http://broadband.motorola.com/consumers/products/SB5100/downloads/542708-001-install-utility-b.exe *** Readme for Motorola SURFboard USB v2.4.1.7 Drivers *** Motorola USB Driver Package for v2.4.1.7 (542708-001-install-utility-b.zip):These drivers provide support for the following operating systems and devices. The Motorola SURFboard USB v2.4.1.7 driver files in this release support thefollowing model modems and eMTAs, including Euro-DOCSIS and International(i)variants for use with Windows 98se, Windows 2000, Windows Me, and for 32-bitversions of Windows XP and Windows Vista: SB4100 / SB4101 SB4200 SB5100 SB5101 SBG900 SBG940 SBG1000 SVG2500 SBV5200 Motorola recommends that systems running 64-bit versions of these operatingsystems use an Ethernet connection for the best performance and user experience. The USB driver files in this release also supports the following modems for64-bit versions of Windows XP and Windows Vista: SVG2500 SBV5200 All the above listed Operating Systems will report the USB driver file versionas v1.30.0.0 for this release. The USB driver set consists of five files: rndismpk.sys bcmndis.sys Motorola.cat NetMotCM.inf usb8023k.sysThese file names must not be changed for successful interaction with the PC. ***NOTE*** During the installation of the drivers, Windows may pop up a warningmessage; "Windows can't verify the publisher of this driver software". If thishappens, select the "install this driver anyway" option to complete theinstallation. "Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries."
Posted on Apr 15, 2009
rcirone203
  • 70 Answers
SOURCE: trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Posted on Jul 16, 2009
Replace keyboard on u 845
Instructions
    • 1 Remove your battery from the laptopicon1.png. Flip the switch underneath the laptop and the battery should pull right out with no tools required.
    • 2 Slide the flathead screwdriver underneath the keyboard securing strip at the top of the keyboard. Pull up ever so slightly, and it should pop off.
    • 3
    • Remove the three screws securing the keyboard to the laptop. The metal brace holding down the laptop will also come up.
    • 4 Flip the keyboard over onto the palm mouse. You will see your laptop connected to one more set of screws; remove them.
    • 5 Disconnect the cable holding in the laptop. The keyboard will now be completely free of the laptop.
    • 6 Replace or clean your keyboard, and reverse the previous steps to reattach a keyboard.
Read more: http://www.ehow.com/how_5942786_replace-keyboard-toshiba-satellite.html#ixzz2yyz9nnGU
Apr 04, 2014 | Toshiba Satellite U845-S406 laptop
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
I got my enter key damaged in my toshiba satellite l310wil i be able to get a spare or another key from the service centre
You have to replace the entire keyboard, the last time I bought one it was about $75 + shipping. You can download the instructions on how to change the keyboard from the Toshiba Tech support pages. Sometimes, it takes some looking to find the right instructions but if you fairly mechanicly inclined you can change the keyboard yourself in about 1-2 hours following the instructions. You have to basicly take the computer completely apart from the bottom to the top in order to change the keyboard. If your not at least fairly comfortable taking your computer a part that far then you should have someone else do it for you.
May 21, 2010 | Computers & Internet
Toshiba Satellite L500 - Keyboard Commands
That is indeed a problem with keyboard commands.
Try to hook up an external keyboard through your USB connector and see what happens.
Nov 15, 2009 | Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Open Questions:
Computers & Internet Logo
382 people viewed this question
Ekse
Alun Cox
