Question about Crane Cams Single-Fire Crane HI-4 Ignition System - 8-2100
Does a electronic ignition-h-1crane cams,,haft to flash when turning over
I got power on electronic ignition going to coil. no spark at coil.when I look at ignition indicator light is on ,but when I turn over it does not flash off and on,,is this right?
    Top Expert:
  • 12,223 Answers
MAKE THIS and fix it.
If nothing happens when you turn the ignition key to the "Start" position, it means that the starter motor doesn't turn over the engine. Most commonly this could be caused by a dead battery;
If the battery checks out OK, but the starter still won't crank, there could be a number of possible reasons. Here are some of them:
The ignition switch could be bad - it's a common problem. An ignition switch is an electrical switch installed at the back of the ignition lock mechanism. If jiggling the key in the ignition helps start the car, the ignition switch should be checked first.
The starter solenoid control wire could have a bad connection.
The starter motor itself or a starter solenoid could be bad.
A neutral safety switch is bad. If a car doesn't start with the transmission in Park, but starts in Neutral, it could be caused by a problem with a neutral safety switch.
A problem with vehicle's security system or some other electronic control module (e.g., ECM, BCM) may also prevent the starter from operating.
does a electronic ignition-h-1crane cams,,haft to  - f6db93d3-a835-4daa-9273-fa7d7b558e85.gifa748ac30-f9e8-4c95-9caf-b0575d5ff047.jpg
Posted on Jul 27, 2013
No spark on cyl 3 and 4
What engine ? 2.2 l or 2.4 L. You don't say if any codes are set. no P0303 - P0304 cylinder's 3 & 4 misfire ? or any other ? No the cam sensor wouldn't cause just two cylinders to misfire. The PCM triggers the ICM to turn on an off coil's to build up an collapse the primary voltage inducing the secondary voltage . This engine is equipped with a non-distributor ignition system called the electronic ignition (EI) system. The primary circuit of the EI system consists of the following components:
Two separate ignition coils
An electronic ignition control module (ICM)
A crankshaft position (CKP) sensor
Related connecting wires
The ignition control (IC) portion of the powertrain control module (PCM)
Important: The camshaft position (CMP) sensor is only used for a misfire detection. It is not part of the ignition system. !
How to Test the Ignition Coils GM 2 4L Quad 4
Jan 24, 2015 | 2001 Chevrolet Cavalier
What else can keep truck from spark besides coil and igniter?
Cam sensor / est electronic spark timer sensor defective coil pack module. A blowen fuse and crank sensor.
Jun 14, 2014 | 1989-1995 Toyota 4Runner Radiator w/ V6...
No spark
Hi David, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
For a prime suspect please visit the website below and good luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 28, 2013 | 2000 Harley Davidson FLSTC Heritage...
93 sportster only fires on 1 side of coil
Hi Lowbrowbob, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
For a prime suspect please visit the website below:
Good luck
Harley Davidson Sportster error codes and how to access them
Oct 06, 2012 | 1993 Harley Davidson XLH Sportster 883...
Cant get a spark
The only other thing you have to look is how the coil is charged up. Is the battery good? Is there 12v on the power side of the coil? Is the coil grounded? Are points or electronic ignition time in use? If mechanical points are in use then there is a capacitor near the points that can go bad. If there are points in use, do they open and close properly when the engine is turning over? Is the gap correct for the points? If this is an electronic controlled timing system, then check the cam or crank sensor for function and gap. That is checked with a volt ohm meter. I'm unfamiliar with your particular bike so I apologize that I can't be more specific.
Aug 03, 2012 | 2000 Honda CM 125 C
2003 Harley Davidson Deuce wont start, No spark
Hi Ray, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
For a possible prime suspect please visit the website below and good luck.
Jun 11, 2012 | 2003 Harley Davidson FXSTDI Softail Deuce
1990 Isuzu 2.6 L 5 spd. No start.. Fuel pressure is ok, not getting spark. Checked coil, ignition module, distributor, computer and coil wire. No power coming from the coil. Small voltage going into...
assuming you the coil, plugs, cap, rotor and wires are good. check the cam sensor, If you have 12 volts to the coil using a 12v light tester. The cam sensor responsible for sending info to the computer telling it that the cam is turning, then the computer tell the coil to dispurse the charge/sparks to the distributor as distributor distribute the sparks to each plugs from the rotor of the distributor. Replace the cam sensor, it tend to go bad over period of time.
Dec 23, 2009 | 1990 Isuzu Spacecab
No spark at coil
check ignition pick-up coil and ignition module
Mar 31, 2009 | 1996 Jeep Grand Cherokee
Crane Cams Single-Fire Crane HI-4 Ignition System - 8-2100 Logo
157 people viewed this question
Top CraneCams Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CraneCams Vehicle Part and Accessory Expert? Answer questions, earn points and help others
