Question about Sewing Machines
I need a User Manual for the Brother Free Arm 6945 sewing machine
  • Sewing Machines Master
  • 7,365 Answers
Check with a1sewingmachines.com and go to the contact us section,, they have a email address and a phone number, ask them about the manual.
Posted on Sep 18, 2013
bargainbox
  • 1388 Answers
SOURCE: stitching looping
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....the question you pose could have 2 meanings....this reply is for looping thread.
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cc3f045.jpg...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes. ie a different colour top and bottom just for the test.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case....no case ? then make some sort of cover ! Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you need any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 23, 2008
informatica
  • 1114 Answers
SOURCE: Looking for the free manual that you advertised
Hi - You can download the manual by clicking the link underlined in blue below:
LS-1217
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 14, 2008
  • 253 Answers
SOURCE: user manual needed
The manuals will sometimes come on CD now, hard to read I Know.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PS_1250_MULTI_1343.PDF
This is the direct link to the manual, you will need the free adobe acrobat reader(You probably already have it) when you click on the link if you cant see it you will know.
Please give a fixya rating if this is what you needed, Thanks.
Posted on Apr 12, 2009
SOURCE: brother vx810 sewing machine user manual
This is an old forum, but thought that I would add a link - http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_VX_807_810_EN_1068.PDF
Posted on Aug 21, 2009
  • 255 Answers
SOURCE: user manual for brother MA4B551 overlock machine.
Hi. Brother is really great about providing manuals for their machines. Go to: http://www.brother-usa.com/Support/ and scroll down to manuals and documentation.
Happy Sewing!
Robbie
Posted on Mar 11, 2010
Need an owners manuel and assesseries for a Brother LX2763
Hello, Lowanna -
I checked the Brother web site for a manual for your model of sewing machine.
You can download (free) and save the manual from this web page:
http://www.brother-usa.com/support/modelinfo.aspx?R3ModelID=LX2763
Click or tap on the link for Manuals & Documents. That will bring you to the links for the Quick Setup Guide and the User Manual.
Both those documents are in PDF format, which means you will need Adobe Reader software (free.)
Also, after downloading the manual, be sure to save it in your Documents folder using a file name you can find again easily - something like: Brother LX2763 Manual.
The manual includes a list of accessories and attachments for the machine. If you need to purchase accessories and attachments for your machine, a local business selling Brother sewing machines may carry them or may be able to order what you need. I also found this website selling parts and accessories for the Brother LX2763:
https://www.sewingmachinesplus.com/brother-lx2763-parts-accessories.php
Best wishes.
Feb 07, 2018 | Sewing Machines
JC Penney Free Arm model 6945. Why won't it rewind bobbin?
Hard to say. But, for ~$25 you can purchase a stand-alone bobbin winder from the local fabric store (JoAnn's or Hancocks) or online from someplace like Amazon.com.
Nov 21, 2015 | Sewing Machines
Where can I find a user manual for the Brother Pacesetter Free arm 6945 sewing machine
Contact Brother in your region, unlikely you will get one from a shop because not many spares were made
Jul 30, 2013 | Sewing Machines
User manual for brother sewing machine lx-3125
This is the site for your help! Just choose the type of your machine and its model and it will give you the complete user manual :)
http://www.brother-usa.com/manuals/default.aspx?productgroupid=3#.T-MTH5GeFS9
Jun 21, 2012 | Brother LX3125 Sewing Machine
Free download for a Brother VX890 sewing machine manual
have you tried the brother website? there is user guides there. start at brother.com then gi ti dimestic sewing machines page
Dec 31, 2011 | Brother Sewing Machines
I need the manual for the Brother Sewing Machine model XL 3022. Is it available on line?
Hi mamajenny...
Sorry I could not find a free user manual for your sewing machine, but I did locate a webpage that you can pay and download the manual..
Please take time to rate me
http://www.tradebit.com/filedetail.php/2992501-brother-xl3022-user-guide
Aug 23, 2011 | Sewing Machines
How Do i Use this product?
Hi tialeatricee...
Your best bet is to have a user manual to explain all you need to know about this sewing machine.
Sorry I could not find a free user manual for you, but I did find a webpage where you can download one.
Follow the link below
http://www.download-manual.com/shop/Brother-LS-2125-Sewing-Machine-User-Manual-pr-10565.html
Aug 16, 2011 | Brother LS-2125 Mechanical Sewing Machine
With my Brother 3750 sewing machine, it is hard to thread because the arm that goes up and down does not come out of the machine "case". I end up trying to almost blindly put the thread through...
Hello, Cwpetronio -
I hope I am correct in thinking your Brother sewing machine is in the XL series of sewing machines. If so . . .
I think you will find the instructive illustrations here helpful:
http://support.brother.com/g/b/faqend.aspx?prod=hf_xl3750eus&c=us_ot&lang=en&faqid=faqh00000467_000
I would think the instructions for threading the machine are in the owner's manual. If you do not have the manual, you can download on free here:
http://homeappliance.manualsonline.com/manuals/mfg/brother/xl3750.html
Note: The manual is in PDF format, meaning you will need Adobe Reader software (free). After you download the manual, I recommend you save it in your Documents folder using a file name you can find again easily - Brother XL-3750 Manual. You can print the manual for easy reference.
Best wishes.
Jan 19, 2018 | Brother XL3750 Mechanical Sewing Machine
Sewing Machines Logo
176 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
