Foxconn lga775 672m01-1.1-8eksh ddr2 mb power button hook up
I need to no were to plug in my power button cord on the motherboard need a diagram
sandrew
  • 2961 Answers
SOURCE: Foxconn NF4UK8AA-8EKRS NO BOOT
Could be one of three things, either your motherboard is faulty (check the capacitors for bulging) and is not getting the power to the processor, the processor itself has faulted, or it's simply a flat cmos battery, as this can cause none starters.
Posted on May 19, 2007
  • 46 Answers
SOURCE: How to hook up the front panel switch for a Quicksilver2-cmt motherboard
You first need to know the make and model number of the motherboard. Most mobo's have the make and model printed on the board itself, other times there will be a sticker.
locate these and let me know what make and model and i can do my best to provide you with the manual.
Thanks,
Brad Nelson
Posted on Feb 21, 2008
hvpatel
  • 152 Answers
SOURCE: Mainboard : ELITEGROUP 945GCT-M3
400 watt
Posted on Feb 25, 2008
SOURCE: memory upgrade from ddr 256mb to ddr2 1g
mhtml:http://www.foxconnchannel.com/upload/Compatibility/200703291139540676P4M800P7MA-MEM-070212.mht
Posted on Apr 15, 2008
wayneard
  • 1901 Answers
SOURCE: can i install 1GB ddr2 on P4VMM2 Motherboard?
This is from the www.crucial.com website for your motherboard:
"Each memory slot can hold DDR PC3200,DDR PC2700,SDRAM, PC133 with a maximum of 1GB per slot."
It does NOT use DDR2. You can go to the crucial site and run a scan on your system. It works pretty well.
Also you can use a video card with a PCI or 4x AGP interface only.
Posted on Mar 23, 2009
Need diagram
There is a 9 pin near below at the sata socket .
the upper pin 1 and 2 pin in left going right side are for power led light. and the 3 and 4 pin is for power switch.
the lower side are the same position but 5 pins.
lower 1 and second pin is for hdd led, the 3 and 4 pin is for reset switch. forget about the last pin, it must be empty
look like this ::::.
start the count from left to right.
do not start from upper to lower
Posted on Jan 09, 2015
Jan 29, 2014 | Foxconn RS740M03A1-8EKRS2H 2 x Ddr2 Mb
No power or lights to toshiba nb205-n210 netbook
Maybe your motherboard is fried. If you know for a fact that the power cord is good and that the DC Jack on the motherboard is good but nothing is happening then the board is just gone.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 05, 2012 | Toshiba Computers & Internet
Where do i plug in the connector for the power button?
You can find it on the bottom right part of the motherboard below the memory ports. It will be called FP1. It will be the upper 3rd and 4th pin. It may say PSWITCH above it. If you want a diagram, you can find it in the manual at the link listed below:
http://www.foxconnsupport.com/download.aspx?models=en-us0000129&category=C000000001&brand=en-us0000002&Series=en-us0000006&chipset=en-us0000058&keywords=&sort=
You will see it under File Downloads. It will be on page 4 of the manual. Hope this helps!
Mar 31, 2012 | Foxconn WinFast K7S741MG Motherboard for...
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
I was running a gigabyte MB ,.then powr supply failed baddly,.. I purchased a used foxconn MB and diffnt PSupply,..I put the CPU on foxconn MB and mounted in old case w/ what I think is good PSupply,.. but...
did you connect the cpu fan and fan 1 power feeds in on motherboard ?
from
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket478/661FX4MR-ES/manual/English/661FX&648FX4MR-Eng-easy%20guide-09-04-04.zip
Sep 05, 2017 | Foxconn 661FX4MR-ES Motherboard
Can't figure out where to put
Geta flash light and look at the lower right hand corner there you will see where they go. Since you did not include your motherboard type I can not send you a diagram but the pins in that corner will be marked so that you can tell where they plug in. You may need a magnifying glass to read the letters saying hddled,power led,pwsw,reset they also have little lines so that you know which way to turn your plug to plug it in. If this helps you leave rating and feedback thanks.
Feb 21, 2010 | Computers & Internet
D865PERL won't power on after power loss. i have two doing the same thing.
Hello there:
The first thing i would check is the power supply if this is not working it needs to be replaced
Also you can unplug the power from the computer and open the case and find the power supply cord that connects to the mother board and dissconnect ti from the mother board ,
now press in on the computer power button and hold for 30 seconds and do the same for the reset button if it has one this will release any (ESD that may have built up ) now just reconnect the motherboard cord that you dissconnected earlier and plug in the power cord to the computer and try to restart
OK? I hope that this has been very helpful for you
Best regards Michael
Nov 16, 2009 | Intel D865PERL Motherboard
Open Questions:
AVAST Support Number 18OO935-6318 password recovery CONTACT AVAST Antivirus TEC-H SUPPORT CAR-E VIPRE DAIL 1800-93S-6318 AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.
Jul 17, 2018 | Contact Computers & Internet
AVAST Setup installations 18OO935-63l8 CONTACT AVAST TEC-H SUPPORT CAR-E AVAST ANTI-VIRUS tech support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number .AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS contact contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS -VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS tech s support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS contact contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS -VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technical s support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number.AVAST ANTI-VIRUS techs support contact number.AVAST ANTI-VIRUS technicals support contact number.AVAST ANTI-VIRUS customer contact phone number.AVAST ANTI-VIRUS customer care contact number
Computers & Internet Logo
David Payne
David Payne
