Question about Garden
22965x8a scott mower
How to replace drive belt on my scotts 22965X8A mower
2 Suggested Answers
SOURCE: I have a scotts model 22965x8a lawn mower that
Sounds to me like it is fuel related have you cleaned the carburator and Bowl ?
If not I would try removing the float bowl bolt located under the carburator .
these bolts are hollow and fill up with dirt and sediment once removed you will see small holes drilled into the side i use a torch tip cleaner but a straight pin will work to unclog .clean any debree from inside of bolt before installing i use spray carb cleaner with the extension will get into the holes well .I would always try this first before assuming the carburator needed to be taken apart and cleaned hope this helps .
Posted on Oct 23, 2011
Replace belt on scotts push mower 22965x8a
You will have to remove the wheel, then you will be able to install or remove the belt. Refer to the diagram:
http://www.ereplacementparts.com/murray-22965x8a-2000-2234-lawn-mower-parts-c-17887_17944_28589.html
Oct 14, 2014 | Garden
Scotts model 46572x8 need to see a drive belt diagram
The lawn mower you have was manufactured by the Murray Company, which has been purchased by Briggs and Stratton. For parts and service, you can contact the Murray Division of Briggs and Stratton at 800-258-5011.
Hilary @ Scotts
Aug 21, 2011 | Garden
I have an older Scotts By John Deer. It has a 48" deck. I need a diagram to put the belt back on. It has 7 turns. main one up front two behind that and 4 across the back. can you help?
For help with Scotts mowers manufactured by John Deere please contact: Phone number: 800-537-8233 Email address: jdlawns@deere.com Website: http://www.deere.com/en_US/scotts/serv_contact_us.html Stacey@scotts
Apr 16, 2011 | Garden
I have a scotts model 22965x8a lawn mower that conks out soon after starting. I have replaced the spark plug and cleaned the fuel lines but the problem persists. Any ideas for troubleshooting since I do...
May 21, 2010 | Garden
I have a scotts riding mower model 2046h 46'' cut and do not know how to change the transmission belt. Thanks for any help.
To whom it may concern, I have a Scott's 2046H lawn tractor # GX2046S042396, I replaced the arm #GY00244 which the original piece was found broken. Now I have the unit back together, but I have no drive, forward or reverse. I checked the belts and pulleys, belt is tight and the pulley's are intact and functioning. Any ideas as to what I should check or do?
Apr 18, 2010 | Garden
I need a diagram of the drive belt on a Scotts 1642 garden tractor. I have an oners manual but it is not in there
I believe this is one of the Scotts mowers made by John Deere. Deere has a parts website that you can access. You enter the model number of your mower, and it then lists the various sections of the mower. It shows diagrams of all the various parts. The drive belt would be shown in one of these diagrams. You can probably figure out the configuration by looking at these illustrations.
A second possibility is to check out www.mytractorforum.com. Join up (it's free), and ask your question. Someone on there has probably done this belt replacement and can either guide you through it or send you a diagram.
Oct 14, 2009 | Garden
I need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Drive Belt routing for Scotts Riding mower
I have to replace the belt part number m124895 on a Scotts riding mower.I need the belt configuration,since i bought it used.
Please help
Sep 25, 2008 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
