Question about Sharp AR-5316 Advanced Digital Imager Copier
Problem the copier is showing L1 i have not tried resolving it please i need assistence
  • emmycool Aug 30, 2007
    i have not seen the reply to my problem L1. thaks
  • 71 Answers
L1:SCANNER UNIT FORWARD MOVEMENT PROBLEMS,POSSIBLY BAD SENSOR, SCANNER MOTOR, OR BOARD I would check that the transit screw that holds the scanner in place hasn't reconnected. The second thing is to lift up the glass and check that you can drag the scanning bit (the mirrored bit that moves) across. That should sort it.
Posted on Aug 30, 2007
What does L 1 mean on my Sharp AL-1540CS Also E 7. Help.
The L1 is for a scanner movement failure. The scanner bar that maoves back and forth under the glass is not moving as it should. The E7 is for a scanner lamp reference failure which CAN be caused by the scanner movement failure so I would try and resolve the L1 first. I have a tip posted here at Fixya that resolves the L1 so try that first and it may fix both problems. If not just comment on this and I will try and help you resolve any remaining issues.
Here is the link to the L1 solution:
Good Luck and Thank You for using Fixya.
Nov 10, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Sharp al 1661 cs shows System error(L1-00)
When your copier scanner is locked then show L1
Solve :Unlock position
clean all surface in scanner area
clean scanner sensor
Nov 05, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Showing Catridge Empty signal with a new catridge
Please try to turn off the printer for a couple of minutes and then turn it back on again.
If problem still persists, please try to install the cartridge again. This time, make sure to follow the steps carefully on how you can replace the cartridge.
Provide feedback so that I can assist you further.
Aug 10, 2009 | HP DeskJet F4280 All In One Printer InkJet
L1-18 code
I don't see a reference to a L1-18. A L1 code is a scanner feed problem. I only show a L1-00 code. Sorry.
Jul 01, 2009 | Sharp AR-507 Copier
My printer showing always scanner error and catraige error
Please use the home product support page for your printer here to access the problem solver and resolve these issues.
I'm not sure exactly which error messages you are getting, but see here for a common scanner error solution, and here is a solution that will resolve most cartridge errors.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | HP Officejet 4355 All-In-One InkJet...
Pls. my Konica 1212
power supply went bad!
try this Reseat CN15 on CB than check the oporation of L1 L2
47 mode 00
hope that help
Oct 11, 2008 | Ricoh Aficio 1013F Copier
An L1 generally means the lamp carage is not moving. Remove the glass and see if that lamp assembly moves back and forth freely or if it is hitting something in it's path.
Apr 04, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
