Question about Food Mixers
Kitchen aid artisan model # KSM150PSBU
I just bought this mixer used, SUPPOSEDLY, from a senior citizen on ebay who said she only used it 6 times and it works perfectly. Anyway, I got it and it was making a TERRIBLE noise! I saw a screw in the back top that was loose so I tightened it! The sound wasn't as bad after. Then I saw the side black screw thing that you use a flat head to get into (a spring of sorts with chalk? on the end?) was loose and so I went to tighten that. Now, the mixer won't work AT ALL! It already was NOT how she described it and I'm angry and frustrated! The bowl is all dented and needs to be replaced and she sent a bowl from a different brand mixer and said it works well and it does not work at all with the stand mixer! Either way, my concern is that the mixer won't even try to turn on any longer. I've never owned a Kitchenaid stand mixer before and I really wanted one terribly and so I'm CLUELESS on what might be the issue and really can't afford to take it somewhere to get it fixed. Help? Thank you so much! :) I appreciate any help you can give me! Jennifer
  • Food Mixers Master
  • 1,231 Answers
You have put the "chalk thing" back in incorrectly, it only fits one way, use a torch and look in the hole and line the missing corner on the "chalk thing" up with the blocker.
Posted on Nov 24, 2013
wavoconqueso
  • 57 Answers
SOURCE: when mixin bread dow the arm of the mixer moves loose
Lay the mixer on a towel and look up inside the base to the top of the neck. There's set screw up there. Tighten. If that doesn't work your shaft may be too worn and needs to be replaced.
Posted on May 08, 2009
SOURCE: Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Posted on May 24, 2009
SOURCE: Knocking sound
Same problem here! How can I fix it? I'm in the middle of important Christmas baking!
Posted on Dec 21, 2009
  • 130 Answers
SOURCE: mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Posted on Mar 30, 2010
SOURCE: I have a KitchenAid Artisan stand mixer (325
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
Posted on Apr 07, 2010
Model 4ksm900b
Google Kitchen Aid in your home country.
Jul 30, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid mixer repair locationsi
Leaking oil is caused by the grease in the gear box separating. This often happens when the mixer is not used much and the grease is not kept mixed by the moving gears. The solution is two-fold. First run the machine more frequently. Second is to open the head and replace the old grease with an approved food-grade grease (6 oz. is the right amount). KitchenAid grease can be found online and at Ebay. The Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
While the Artisan series is not specifically referenced, the procedures are the same.
You can also take the mixer and manual to a competent repair person.
Jul 13, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Mechanical burning smell on kitchen aid stand mixer
i think its time to retire it its has had a good run time to put it to rest and buy a new on it don't sound safe to use anymore
Sep 21, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Need bowl and mixer attachments for Kitchen Aid Artisan Mixer
We've found most all accessories at any place that sells the mixer. Bowls, beaters, meat grinders, pasta makers, etc.
Jan 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food Mixers Logo
107 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
