SL PD 987 Pitch Control Knob Replacement part
Looking for the replacement part for the Pitch Control Knob Is this something I can buy from you
    Top Expert:
  • 12,223 Answers
Go please to http://www.partselect.com/ and get it
God bless you
Posted on Jul 27, 2013
Where can I buy the reflector for a ray-line #41120-1110
Did you ever find a source? I am looking for a bulb for this same unit, and also a gear mechanism for tilt.
Apr 23, 2012 | ITT Jabsco Jabsco 135 Sl Remote Control...
Our Technics SL-1200MK2 has issues with the direct drive. It does not spin at a constant speed. When stopped, it does not stop immediately. What can be done to solve this?
To adjust stopping speed you'll have to remove the plate by pulling it up. Then there is a plastic cover that has some screws, remove the screws and remove the plastic cover, you'll find a variable resistor that reads something like brake. Adjust it to the left or to the right with a screwdriver and see at which position works best.
To solve the constant speed problem you'll have to replace the pitch regulator.
Go to any panasonic/technics service and buy the pitch. If you have a bit of soldering skills you'll be able to replace it by yourself. You can access the pitch regulator unscrewing all the screws under the device and then removing the cover.
Hope you can solve the problem!
May 18, 2011 | Technics SL-1200MK2 Turntable
When using my pitch controll the spped does not
the pitch control slide potentiometer needs to be replaced. This is a common failure on the sl-1200 series.
Apr 22, 2010 | Technics SL-1210M5G Turntable
MY Technics 1200 Rotates Out Of Control. What needs To Be Done To Fix?
It sounds like you need to replace the belt. If it's too loose, it will not maintain the proper speed.
Nov 04, 2009 | Technics SL-1200 Turntable
Pitch control drops drastic in middle of set
it sounds like the problem is the pitch control. this is a common problem that can be fixed pretty cheap check out 1200s website they offer alot of help and replacement parts for this issue.
Jul 05, 2009 | Technics SL-1210MK5 Turntable
Stiff Pitch Adjustment
What did you open up? The top of what? If you could be specific, I can direct you.
If your pitch is stiff, try spraying some contact cleaner or similar - DO NOT USE WD40. Use an electrical contact cleaning solution, such as CAIG DEOXIT or CAIG FADERLUBE both work very well, and are good for electronic contacts.
If this does not work, then maybe the pitch control knob/shaft is slightly bent? Any physical damage?
Other than that, there isn't a whole lot you can do, unless you replace the pitch control - Technics Pitch Control.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 14, 2009 | Technics SL-1210M5G Turntable
Broken pitch control
Yep, time to replace the pitch control. You can attempt to do this yourself, however good soldering skills are required (not the time to learn). You will have to desolder the old pitch control, and solder on the new one. Which is why I say, now is not the time to practice soldering on your turntable. You could actually cause more damage.
If after replacing the pitch control, you still have the same issue, then there is something wrong with the drive on the unit. The drive is controlled by various integrated circuits (IC's), and they are known to short out every now and then. The problem is isolating the correct IC. FYI, Technics is starting to discontinue parts, and 1 of the main IC's on this unit is no longer available (IC302 - Nand Gate).
You can order the PITCH CONTROL HERE.
DJ PRO LAB
www.DJPROLAB.com
Apr 06, 2008 | Technics SL-1210 Turntable
1210 mk 2 strangeness
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Dec 01, 2007 | Technics SL-1210 Turntable
Pitch adjustment light is always on
Ok DJ,I use to Dj too,Probley you have moved the equipment quite a Few times,Is the Table Synchronous if so you might have some dust in you control throwing it off,Also Different locations have ac Voltage differences,Ck that too... Other wise go to radio shack and pick up some Contact cleaner Good luck let me Know ttech
Jul 24, 2007 | Technics SL-1200MK2 Turntable
42 people viewed this question
 Grubhead
Grubhead
