Question about Breville Fresca BES860 2Cup Coffee Maker
I can achieve normal pressure only by using dual wall baskets.
When using single wall basket pressure gauge displays low water pressure and I get sour coffee with no crema. What may be a reason? Thanks.
    New Friend:
  • 4 Answers
The grind is too coarse or the tamping is too light, or a combination thereof. Use some bathroom scales to get your tamping pressure right and then adjust the grind accordingly.
Posted on Sep 25, 2013
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Coffee is not filtering through the coffee
Adjust the grind and or tamping pressure.
Posted on Sep 17, 2009
  • 50 Answers
SOURCE: The coffee comes out like dirty water with no
too much coffee. are you filling it too high? does it take a filter?
Posted on Jan 24, 2010
  • 18 Answers
SOURCE: Can't get tight fit between basket & steam ring
the proper replacement steam ring has an up-side & down side. the brew-head plate must be installed with the grooved side facing up; the steam ring has a groove in one side that fits over the top up the brew-head plate...does this solve the problem? if not, you may have the wrong steam ring/the brewhead plate may be installed incorrectly...oh, nov of 08...i seriously hope you've figured this out already. if not, you don't happen to still have machine in your possession, do you? if so, i'll buy it for $5.
Posted on Jan 11, 2009
Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
Jan 12, 2013 | Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity...
Poor water circulation, not enough pressure to move polaris around adequaately
Check the basket at the skimmer and the one on the pump and make sure they are clear. If you have a pressure gauge on your filter does it read higher or lower than normal? If it is higher that would indicate a dirty filter and needs to be taken apart and cleaned or backwashed. If it reads lower than normal the problem may be a clogged impeller, where debris has gotten past the pump basket.
Dec 18, 2012 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
I just bought a Breville BES860 Fresca Espresso Machine and when I tried to put the basket into the portafilter, it doesn't fit. The portafilter came standard with the machine. Do I need a bigger...
They require a bit of effort to push them in when new, you should have gotten a set of single wall and dual wall baskets. There is a spring clip inside the grouphead (portafilter) and you have to overcome the clamping of the spring it is a reasonably tight fit to stop the basket retaining in the machine.
Jul 02, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Brand new machine and the pressure gauge doesn't appear to be working, I've made about 10 coffees over the weekend and experimented with the tamping etc. And the gauge has not moved once? Am I...
It could be a faulty machine, what is your grind setting? Make sure your using the dual wall single cup as a test. Set the grind to around 13 and grind your own beans, don't use supermarket bought beans or preground coffee. Both are garbage.
Also if your using the dual wall basket, make sure that you leave the dial guage in the dual wall setting. Then tamp the coffee so it sits roughly 3-5mm below the rim, this is what I have found is best for this unit.
Then secure group head in to unit, press single cup and you should hopefully get a pressure reading, if it isn't going up you are under extracting and your grind is prob to coarse (correct me if I'm wrong), I've found 13 is not to coarse not to fine. Shouldn't feel like fine sand, when coarse but not powdery.
If the gauge does not move in to the grey area your unit is most likely faulty.
Jun 05, 2011 | Breville Fresca BES860 2Cup Coffee Maker
With the BES860 set to Dual Wall for full automation, even on the lowest auto grind volume setting, the grind volume is too large and it spills over. This is on double setting and using the double filter...
If your using the dial gauge with a dual wall basket, you need to leave the dial in the dual wall setting. If you move it beyond the dual wall setting, you are basically adding more volume to the basket. Leave it in the dual wall setting for dual wall baskets.
Otherwise it may be faulty, it could be your grind setting, try it on 13 and see how it goes.
May 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
My pressure gauge never moves... do you have to set it up? if so how.. if not when should it work??
Yes, the pressure gauge most definitely should move. The only reason it wouldn't move, assuming no fault, is if there is no resistance for the water between the pump and the outside world, which would be theoretically possible only if your coffee wasn't ground fine enough, or wasn't tamped at all. FYI, the pressure gauge on mine normally ends up at around 1/3rd to 1/2 way around the dial, depending on factors such as grind, tamping, freshness of beans, and whether I use the standard pressurized (dual-wall) basket, or one of the older non-pressurized (singe-wall) baskets.
Failing these obvious issues, you probably have a faulty or disconnected gauge. But how's the coffee?
Steve
Feb 08, 2011 | Breville BES820 Espresso Machine
Suction on vacuum is low, pressure in filter is low and pump appears to be louder then normal what's the problem
If pressure gauge on filter is low, then most likely problem is obstruction is suction side of plumbing, which includes a clogged impeller. double check impeller, this can be hard to get to without unbolting the two halves of pump, separating the two, and removing the diffuser so that you can fully inspect the impeller. You can try using a wire with a little barb on the end and trying to pick at the center of the impeller from within the pump pot (where the basket goes), but if this doesn't reveal anything, taking pump apart to reveal impeller is the best bet. Before you take the pump apart, (or after if you've already done so.) make sure pump basket, skimmer basket, and any leaf traps are cleaned out. Make sure any valves on the suction side are fully open to allow as much flow as possible. (you can open and close these later to single out the problem if it is a plugged vac line) Disconnect the cleaner from the wall or skimmer to eliminate a clogged cleaner from the possible causes. A bad o-ring, or air leak somewhere can also cause low, or bad suction. so make sure the pump lid o-ring is sealing properly. Also check the pipe that goes into the pump (suction side) If this is loose, or letting air into system, that will also affect suction. You should be able to find your problem if you check all the above. If not let me know by posting a comment, and I'll help you further. Every pool, and equipment are different, and there are endless possibilities to where your problem can be, but eventually you can narrow it down to the problem. Good luck and let me know how it turns out.
Oct 04, 2010 | Pentair 011516 WhisperFlo FullRated Energy...
My single cup portofilter on my ECM Giotto suddendly is pouring more coffee then it should. I'm using the same grind I've been using forever. My other portofilter (2 cup) works fine and still produces the...
How old is the coffee being used? Normally if you change baskets, the grind should be the same, because the single basket has finer and less holes in it than the double basket. The only difference would be the tamp then, since the coffee grinds works great with the double basket. You would also have to use a different volume of water to produce the coffee. To produce 2 ounces of espresso you need about 3 ozs of water,(about an ounces of water will remain in the coffee).
Jul 19, 2009 | ECM Giotto Espresso Machine
The filter basket on my FrancisFrancis X5 sticks to the machine.
Place a glass under the filter basket. Do not return the portafilter. Pull another shot. The pressure will push the filter basket off.
Apr 01, 2009 | FrancisFrancis! X5 Espresso Machine
Handle is pushed out
Are you using the pressurized filter baskets? My 2 1/2-year-old SL70 recently started doing the same thing, and I think I have narrowed the problem down to the filter basket (it works fine with a non-pressurized basket). I've ordered a new pressurized basket. I can't guarantee that this is the answer, but you might try it.
Feb 12, 2008 | Solis Crema SL-70 Espresso Machine
Breville Fresca BES860 2Cup Coffee Maker Logo
285 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
