Question about Watches
I recently purchased an invicta angel model 0696. The watch isn't keeping time I replaced the battery and pressure tested it. I also did the manual reset button as well. The watch has been ticking perfectly for the week i have had it until today. Now it stops and goes? Is there are certain way to set these watches? How do I set the chronographs as well?
  • 73 Answers
SOURCE: Two cheap chronograph watches that won't set date and month
I would need the models on all watches to answer this question. I would make sure that the crown really doesn't pull out to a second position. They can be a little stubborn sometimes.
Posted on Dec 31, 2007
escapement
  • 2334 Answers
SOURCE: how to set a Honora chronograph watch
You have to upload here all details of the watch: model, ref. number. Movement number and good pic would be very helpfull.
Posted on Dec 21, 2008
ONECCO
  • 3 Answers
SOURCE: Just had battery changed in my Tag chronograph.
I love these watches, don't you?
Posted on Aug 16, 2009
  • 183 Answers
SOURCE: SET THE TIME ON MY TOZAI ALARM CHRONOGRAPH WATCH
Here is a copy of the instructions.
http://www.tissot.ch/virtualdata/usersmanual/138-en.pdf
Also a Youtube link that will help if your not clear. This one is best shown how as opposed to me typing.
http://www.youtube.com/watch?v=jm73y5o-Fqw
Posted on Sep 18, 2009
  • 3 Answers
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Posted on Dec 01, 2009
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
Watch not runing model 5030
That watch is powered from a 371 button cell1 battery. It is using model 9238/1970 movement. That movement is not listed as a chronograph.
Dec 12, 2013 | Invicta Watches
How do you get battery out of watch? Do I have to take out all screws and remove top piece?
The back of the watch has six rectangular notches around the edge. Using a jeweler's case wrench and 4-pin vise to hold the watch align the three teeth of the watch to three of the notches on the back and turn counter-clockwise. Considering that the tools alone are going to cost you a minimum of $30 - $40, and then you'll have to purchase a battery for $5 - $7, I'm going to recommend that you have the battery professionally replaced for $10 - $15 at your local jeweler. Keep in mind, I'm also considering the fact that you suggested dismantling the watch in order to change the battery. This is obviously an indication that you have no experience in the most basic servicing of a timepiece and to ensure that your timepiece isn't damaged, you really should leave this to a professional. Watch Back Example and Case Wrench captainhawk1_16.jpg
Jun 19, 2011 | Invicta 2358 Wrist Watch
I recently purchased an Invicta Outdoor Trail Edition Men's watch, model J401668. The manual states to pull the stem out to the first click and rotate it counterclockwise to set the day. It does not...
You're probably pulling it out to hard. Solution: pull the stem out completely and carefully try to push it back in for one click only, then attempt to set the date. If this doesn't work, return the watch as it is defective.
Jun 09, 2011 | Invicta Watches
Watch has started
We had the same issue. Replaced new batteries etc. Since it was an expensive Invicta watch and less than a year old we assumed it was perfect. However, you need to take it into a upper end service center and have it "serviced" they will oil, align, etc and it will probably solve your issues.
May 05, 2010 | Invicta Extreme II 9982 Wrist Watch
I just purchased an Invicta Sea Wizard Chronograph Watch, and after taking it out of the box I noticed the large second hand does not move. The watch seems to keep time, but the scond hand is frozen in...
The large second hand is actually the GMT hand for a second time zone. The second hand is the small sub dial at the 2 o'clock position. The large hand with the red arrow is the alarm time.
Nov 18, 2009 | Angel Invictas-More Styles - ELITE...
Have an Invicta Lefty Quartz Chronograph. The subdial that marks the minutes fails to reset to 60, though the large second-hand resets perfectly. Recently I bought another Lefty and had the same problem. I...
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
May 09, 2009 | Invicta Lefty Chronograph Watch with Band...
Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to www.invictawatches.com and find out.
Regards
Arthur
Dec 16, 2008 | Invicta Speedway 9223 Wrist Watch
Watches Logo
14 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
