Question about Polaroid TDA-03211C 32 in. LCD HDTV
Color distorted looks like neon? - Polaroid TDA-03211C 32 in. LCD HDTV
Colors are phychedelic
Dunno but I guess it can be a setting that somebody changed.
You can try to reset it to factory default or go through all the settings.
Nov 08, 2013 | Toshiba 32HLC56 32 in. HD-Ready LCD...
The color is extremly messed up...peoples skin is redish and the green is like a neon color? How do I adjust the color frm the back of the tv?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 05, 2011 | Philips Magnavox 9P6034C 60" Rear...
Upper left corner is distorted and neon green
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 06, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Our Sony KP-51WS510 TV has a blurry and doubled "neon green" picture. What we can do? Thanks for your help!
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-51WS510 51" Rear Projection...
The colors on my TV are shadowing each other in different colors. Such as blue and red.
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
Mar 07, 2010 | Televison & Video
Colorwheel?? Tv has bad color and quite blurry on
Based on the Model# provided, your TV does not have a color wheel. Could be one of the PCBs is bad, or even the panel. Have a TV technician look at it.
Good luck
Nour BMI
Feb 05, 2010 | JVC LT-42E478 42 in. LCD Television
Colors don't line up, and screen is distorted on a sony KP43HT20
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
Dec 08, 2009 | Sony KP-43HT20 43" Rear Projection...
Screen is bright neon pink!
Did you also replace the power inverter when replacing the screen???
Feb 13, 2009 | Acer Aspire 5610-4648 Notebook
The color on the top left hand corner of my tv is distorted kind of looks like the color flapped down over itself
you should keep away your crt from magnetic field. You can use strong magnetic field to pull out the color distortion
Mar 22, 2008 | Televison & Video
Polaroid TDA-03211C 32 in. LCD HDTV Logo
20 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
