Question about Frigidaire Affinity ATF7000E Front Load Washer
My washer has water in tub after the washing cycle
  • Official Brand Answer
  • 4,342 Answers
Hello Romy, approximately about how much water is left after the cycle? In this case, I would recommend reprogramming the washer by either unplugging it or flipping the household circuit breaker. It is important to wait ten minutes and then turn on the unit. If the issue persists, then more than likely the washer could possibly have a faulty fill water valve that is allowing water back in or not draining properly.
Posted on Jul 29, 2013
  • 3422 Answers
SOURCE: Front loader will not spin
You will have to get it repaired that's the only solution.
there being a bad connection wire between the motor and the control board.est the fuse(s) on the control board. If they are bad, then the control board is in need of replacement.
Goodluck,
Please don't forget to rate the solution
Posted on May 06, 2008
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
  • 10 Answers
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Posted on Jan 02, 2009
philbran
  • 242 Answers
SOURCE: washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Posted on Jan 28, 2009
  • 35 Answers
SOURCE: spin cycle doesn't cut in
turn program knob to spin and hit start then hit cancel within 5 seconds hold down options and start/pause button this will put you in the self daignostic test
Turn the program knob (1) click clockwise from the
start position. The hot water solenoid will activate
and hot water should enter through the detergent compartment
Turn the program knob (2) clicks from the start
position. The bleach water solenoid will activate and
cold water should enter through the bleach compartment
Turn the program knob (3) clicks from the start
position. The bleach and the wash water solenoids
will activate and cold water should enter through the
softener compartment.
Turn the program knob (4) clicks from the start
position. The door lock solenoid will deactivate and
the loading door can be opened.When the door is
opened, the drum light should turn on.
Turn the program knob (5) clicks from the start
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
Turn the program knob (6) clicks from the start
position. The drain pump & door lock solenoid will
activate and the washer will operate in high spin.
then on the last turn it will give you the other error codes it has that code is giving usually is caused by a different code to clear the codes
• Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared. you really need to clear that code first to do the test but it can be done in the daignostic test skip the rest first go straight to the 7 clicks and clear the code but dont open the door during the test otherwise it will give that code after you get it cleared go to the spin spot on the knob and keep turning clock wise to go through the test but give it at least 3 seconds for each test then it should display a different code and what ever it is email me and i can help you out at that point nick_bradford2003@yahoo.com i have alot of experence with appliances
Posted on Jun 07, 2009
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
Water will not drain. sewer line is not pluged. Customer service says I could have a plugged filter at the pump ( we have dogs). How do I get to the pump to unclog it. Model EIFLS55IIW woody
Hi agnes! Washing machines, including those built by Frigidaire, have internal pumps. These pumps help drain out the water from the washer tub between the wash, rinse, and spin cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the water can become trapped in the washer tub. In both cases, the pump assembly needs to be replaced. You can check by looking for a few signs that a pump is dying or already dead.
1 Start the washer and wait for the washer tub to fill with water. If you do not hear water or hear a motor whirring, the washer motor may be dead.
2 Open the washer lid in mid-cycle. Note whether or not the inner tub is still spinning around. The inner tub is the inside surface of the washing compartment with many holes for water draining. If the tub is not spinning but the motor is running, it is possible the pump is dead. Check the pump pulley by removing the pump from the washer and trying to rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff, replace it. Also, if the agitator is moving but the tub isn't, this is a sign the pump is dying. For front-loading washers, do not attempt to open the door mid-cycle. Look through the glass door. If there is enough water to come up against the door, the pump is malfunctioning.
3 Wait for the washer to finish its cycle. Open the unit. If water is still in the tub, the pump is likely dying or dead.
Sep 04, 2013 | Electrolux EIFLW55I Washer
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
341 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
