Kenmore front load washer 970 c41032 00
10 year old washer. Noticed loud knocking sound. Then over the next few washes noticed shredded plastic in clothing and waste water. When I open the door I notice wearing on the plastic rim (outside drum?). I've taken back of washer off and there is no noticeable damage. When I spin the metal drum (inside drum?) by hand I can hear a knock at the same point every time, also there is a lot of play in the drum such that it wobbles and easily comes in contact with the plastic that is wearing. Thank you for any help you can offer! Gabriel
  • I have the exact same problem. Same model number, same shredded plastic on the clothes. Mine started after washing an unbalanced load -- a thick, heavy bath mat. I'm not an expert, but my suspicion is that the washer is pooched. I may take out the drum and look inside if I can find the time. Good luck!
    New Friend:
Your spider assembly has corroded and broken. The exact same thing happened to my own washer (same model number as yours). Here's a picture of what it looks like inside.
kenmore front load washer 970 c41032 00 - 6242bb5f-6181-45a1-bd68-9973e6a63325.jpg
This other guy made a youtube video demonstrating the same problem with his washer. As explained in the video, the replacement part cost $200 (in 2007).
After taking apart my own washer, I can tell you that it's not easy to replace this part. It took me several hours to get the washer apart. Even if I were to replace the defective spider assembly, I doubt I could get it back together without screwing it up. Also, the drum's scratched all to hell. Time to get a new washer.
Posted on Oct 05, 2013
SOURCE: kenmore 417.29042992 front loader washer
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
Posted on Jan 28, 2008
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Water Building up Inside Front Load Washer when not in use
Okay, it is normal to hear water sloshing around inside the wash tub when the washer is not in use. A small amount of residual water remains in the wash tub under the wash basket (stainless steel tub), and resides in the drain line and drain pump. That's why it is important to keep the door slightly open when not in use to allow the drum to air out. The water will not evaporate, but it will help reduce the build up of odors, mold and mildew.
Now...if your washer is slowly accumulating water in the wash basket area over time, your water inlet valve is probably starting to fail. The leak can be very subtle and you may not notice it. The water only comes from one source - the fill valve via the dispenser. If you wish to replace it, the part is available at searspartsdirect.com. Just type in your model number and the part you need can be found under the "Dispenser" heading as item number 1. The replacement is very simple if you follow these steps:
1. UNPLUG the washer and turn off water supply.
2. Remove both fill hoses.
3. Remove the top panel of the washer by removing the screws that hold the panel in place in the rear of the washer.
4. Slide the top panel back, then it lifts off.
5. The water inlet valve is located in the left rear of the washer as facing from the front.
6. Remove the rubber hose leading from the valve and the electrical connections.
7. Remove the mounting screws holding the inlet valve in place.
8. Re-install new valve using these steps inthe reverse order given.
I hope you find this information helpful. If you have further questions, please post back and let me know.
Posted on Jun 06, 2008
  • 112 Answers
SOURCE: loud banging on spin cycle frigidare washing machine model no. fws235rft2
If this is a front loader this is a common problem. Unfortunately, it is also a very extensive project (about 8 hours). The tripod supports that attache the drum to the center spindle commonly break. The remedy is to replace both the front and rear tub, and the basket as well. It is also recommended that you replace the drain pump as well. Generally, they will cover the parts (not including the drain pump) under warranty but the labor will be a customer pay.
Posted on Oct 19, 2008
  • 112 Answers
SOURCE: Burning smell, loud when spinning, bleach spots
Usually this is due to the tripod mount on the back of the drum cracking. Simply replacing the bearings does not help in most instances. The only true remedy is to replace the drum, along with the front and rear tubs. These are usually covered under warranty but the labor (6-8 hours) is a customer pay unless the unit is very new. Also, it is recommended that you replace the drain pump as well when performing this repair. It is a good idea to get this looked at as soon as possible as more damage can incur. I have seen them vibrate so violently that they break the control boards above the drum. If you give whirlpool an earfull, they may or may not offer some help on the bill.
Posted on Oct 23, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
While washing heavy load (towels) spin cycle became very loud and sounded out of balance. After cycle finished, noticed several small pieces of white material. Washed a light-weight load next; same loud...
I had exactly the same problem, sound and everything. I just pulled the front off the washer and discovered that I half mooned shaped, big hunk of concrete was broken in half and hanging down rubbing who knows what. I'm sure it's just a weight to help make it stable while spinning. I don't know if the broken concrete is a result of another problem or not. I'm going to try to find a replacement and install it myself and see if it's fixed. I can just hope.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore 970-C41062-00 Spin cycle, belt keeps coming off
sounds as if yo umay have a bad rear bearing, and the off balance of it is "throwing " the belt. magor repair, and would ck with manufacture, for possible part warr
Mar 18, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load won't drain spins then blinks no spin
Yes this is the place, but you have to mop up the water or it would flood the place; clean out the muck from the filter and refit carefully. You have to clean your filter according to usage, the filter does not self clean, no way.
Feb 25, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
