Question about Emerson Televison & Video
Brightening dimming tv
My screen will be normal then will darken unexpectedly
    Top Expert:
  • Emerson Master
  • 74,136 Answers
Check for any loose solder terminals at its video output section. This board can be located on the CRT base, will directly plugged on to its back.
Posted on Jul 27, 2013
Have a Samsung 55" LED UN55FH6030F, dims to about 50% no matter the picture mode (dynamic, Standard etc) If I change input, screen goes really bright, then darkens to 50%, no lines or dark areas.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 13, 2016 | Samsung Televison & Video
Panasonic dmp-bdt220 causes the screen to darken and lighten
It sounds like you have the unit's analog video outputs connected to a TV/Video combo or some time of a recording device. Going through a recording device can cause the image to brighten and darken.
Mar 04, 2014 | Panasonic DMP-BDT220 3D Blu-ray DVD TV
My screen brightness its lees
Then brighten it. You brighten it by Holding Down either FN, CTRL or DEL key + Hit the corresponding key for brightening the display.
For example on my computer I press and hold the FN Function key while I hit the UP Arrow key to brighten the screen.
The brighten/darken keys normally have the icon of a circle with sprockets around it like the sun or it looks like a washer that goes between a screw.
Mar 23, 2012 | Toshiba Qosmio G45-AV690 17" Laptop PC...
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
How do you dim the screen, and brighten the screen on the texas instrument ti-85
Turn the calculator on. Press and release the 2nd key, then press and hold the down-arrow key to lighten the screen. Press and release the 2nd key, then press and hold the up-arrow key to darken the screen.
Aug 15, 2010 | Texas Instruments TI-85 Calculator
How do you make the lighting on the screen brighter without the charger in ?
The screen will automatically dim slightly when it is on battery power, this is to conserve battery power. For maximum brightness connect the power adapter into the laptop.
On the Thinkpad laptops you can adjust the brightness by pressing and holding down the blue Fn key plus the Home key to brighten or the End key to dim the screen.
Nov 26, 2009 | Lenovo ThinkPad T61 Notebook
The screen on my Toshiba satellite p205 went dark on me i check and u can see the window but really dark i replace the lcd screen and the problem persist help please what can the problem be my video...
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 24, 2009 | Toshiba Satellite P205-S7806 Laptop
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
I accidentally dimmed my display screen, how do I fix it?
Hold the 2nd function button down while pressing the up arrow to darken the screen, alternatively hold the down button to brighten.
Nov 11, 2008 | Texas Instruments TI-84 Plus Calculator
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
